Getting either aftermarket 18" or 19" Wheels. NEED HELP!
Old May 1, 2012 | 06:52 PM
vqsmile's Avatar
I would run 225/40 up front and 245/40 out back. That will give you a minute bit of stretch to help clear the fenders and will look/handle great. You might consider rolling the rears just to be safe. If you don't drop you shouldn't need more negative camber, car should align to stock specs with no issues.
I'm curious why the 225/40 in the front instead of a 225/45 ?
The front-to-rear diameter differences with the 40's are 2.4%, whereas with the 45's they're only 1%.
Old May 1, 2012 | 09:15 PM
mavs1balla's Avatar
I have a set of 2005 G35 Coupe rims on my 2008 G35xS, 245/40/19...Fits perfectly never rubs. Im rolling stock springs no spacers or anything.
Old May 1, 2012 | 09:17 PM
mavs1balla's Avatar
here is a pic
Big Booty Trudy's Avatar
I like the 2.2.2
Old May 1, 2012 | 10:38 PM
Blue Dream's Avatar
I drove ttrank's car solo
Hmmm good question. I've run the 225/40/19 and 245/40/19s for a couple of years on 8.5 and 9.5" rims and love the combination of comfortable ride and great handling. Not to mention that's the stock size tires on the 05-07 coupes with the OEM rays. Since it's less than 3% different F/R I've never had VDC issues.
Old May 1, 2012 | 11:19 PM
krzxballer's Avatar
THANKS for the info! i think ima going to go with you and Blue Dreams Advice and stick witht he 225/40/19 front and 245/40/19 rear!
Old May 2, 2012 | 11:41 PM
krzxballer's Avatar
here is a pic
What are the wheel widths on those rims your running? 8.5 front 9.5 rear?
Old May 3, 2012 | 05:15 AM
Blue Dream's Avatar
8"F +30 and 8.5R +33
Old May 3, 2012 | 04:49 PM
krzxballer's Avatar
Because my wheel widths are F 8.5" and Rear 9.5". You think the extra .5" in the front an 1" in the rear will rub?? Man really dont want to rub...
Old May 3, 2012 | 05:07 PM
soundmike's Avatar
It's a bit more complicated than that. Assuming same offsets, that width is distributed inside and out.
So, for your 8.5 +30 fronts, the inner barrel will be 6mm closer to the suspension parts. The outer barrel will also be 6mm pushed out towards the fender.
The rears will be 13mm in and out respectively.
The width of the tires will also come into play depending on width and profile.
Old May 3, 2012 | 09:53 PM
krzxballer's Avatar
So the only way to know if i need to roll my fenders and if they will rub is to mount them with the tires and see?
Old May 14, 2012 | 07:10 PM
krzxballer's Avatar
Anyone know if running 245/40/19 all around would work?!
KruZZe
Feb 27, 2023 05:04 PM
jeffbdye
Jun 1, 2018 03:51 PM
04G35NYC
Winter Setups
34
Jun 2, 2016 09:12 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
TurTLe*
Sep 29, 2015 01:43 PM
