Exhaust Tips
Old May 27, 2012 | 01:44 PM
Ernie3647's Avatar
Exhaust Tips
Has anybody ever been able to find a replacement for the exhaust tips on the 2007-2008 G35 sedans that doesn’t require an exhaust modification of any sort? I haven’t and I’ve looked for a long time. The stock ones are basically slip on. So to clarify I’m looking for the same kind (slip on) but different style. Any input on this is welcome.
Old May 27, 2012 | 02:22 PM
bluedevils95's Avatar
Did you check the junk yards?
Old May 27, 2012 | 03:41 PM
Ernie3647's Avatar
The standard ones are obtainable. I can get them on Ebay. I’m looking for an option to the standard one. Of course without any necessary modifications to existing exhaust system. The problem is that the standard exhaust pipe end swells out to an increased diameter to accommodate the existing sleeve. (Exhaust tip) That is the reason a normal tip will not work without modifications. (Cutting)
Thanks
Old May 27, 2012 | 07:58 PM
kool_yaar's Avatar
couple of people here attached the GTR tips which look big for the car imo but some folks liked it
Old May 27, 2012 | 08:00 PM
kool_yaar's Avatar
here you go...
Old May 28, 2012 | 08:44 AM
Ernie3647's Avatar
Like the look but here’s the problem…..
No welding needed, had to cut the tip off to cut the pipe as close the the end to save enough pipe to slide these on to have a solid connection.
I also had the shop put in some washers to give me more space between the tip and the bumper.
There is a bracket that is holding up the muffler, we put the spacers there to let the muffler hang a little lower.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
