2005 g35 used oil analysis at 175k miles
Old Jun 19, 2012 | 02:14 PM
IP05G35's Avatar
VQ35DE will last forever with proper care.
Old Jun 19, 2012 | 02:17 PM
IP05G35's Avatar
Mods: can you move this to right forum.
Old Jun 19, 2012 | 03:44 PM
Footballmania32's Avatar
How much oil do you have to send for an analysis? And what is the cost? I would love to start doing this now and for my future vehicles.
Old Jun 19, 2012 | 04:10 PM
soundmike's Avatar
http://www.blackstone-labs.com/ <--- Everything you need to know.
Old Jun 19, 2012 | 04:47 PM
stevesg35's Avatar
To the OP, I can't really follow the results but unless I'm wrong, you had your oil tested four times, twice at 6K, once at 10k and once at 5k. Is that right? Also, what oil/oils were you running. I'm mostly curious as to whether the 10k oci had acceptable results and what oil you used. I'm using Mobil 1 EP 5w30 and a Fram Xtended Guard filter with 7,500 mile intervals as that interval works well with tire rotation for me. Thanks for any info.
Old Jun 19, 2012 | 04:48 PM
stevesg35's Avatar
To the OP, I can't really follow the results but unless I'm wrong, you had your oil tested four times, twice at 6K, once at 10k and once at 5k. Is that right? Also, what oil/oils were you running. I'm mostly curious as to whether the 10k oci had acceptable results and what oil you used. I'm using Mobil 1 EP 5w30 and a Fram Xtended Guard filter with 7,500 mile intervals as that interval works well with tire rotation for me and it's a pain to go to my indy, but I occasionally wonder if I'm pushing it too long. Thanks for any info.
Old Jun 19, 2012 | 05:17 PM
stevesg35's Avatar
Old Jun 19, 2012 | 06:58 PM
soundmike's Avatar
The OP had tests done at 52, 61, 79k and again at 175k. Basically, the first row shows how long between oil changes, the second row shows mileage on the engine.
Old Jun 19, 2012 | 08:45 PM
IP05G35's Avatar
The 10k run was Amsoil ASL 5W-30 if I recall and it was perfectly fine to run it that long. Could have ran it longer actually. If you want to see if you can extend your interval using Mobil 1 EP send in your UOA and ask for a TBN reading which is $10 extra. You should be able to run 7500k mile intervals with regular M1 no problem. EP is really good for 10k-15k intervals.
Old Jun 19, 2012 | 09:57 PM
blnewt's Avatar
Good oil but I would highly recommend a better filter since it's so important. K&N, Mobil 1 are all I use, but I've heard Wix are also a good choice, Fram not so much
Old Jun 20, 2012 | 08:36 AM
soundmike's Avatar
Yep, i've ran UOA and TBNs on the various Nissan's i've owned over the past decade -- it's great knowing how well things are working in that aspect of the car's life. Most i've ever done was on my Maxima at 12k or so and the oil was still good.
Currently i've been exclusive on the M1 EP oil and filters, oil results are still coming out good and TBN's have been good enough that pushing to 10k would not be an issue. However... (below)
Ditto on the Mobil 1 stuff. But, i seem to be having oil evaporation (burning?) issues. On every 7+k mile interval, i've had to add half a quart or so of add-on oil, which is considered normal, but have not been able to drain more than 5 quarts come oil change time (like i used to earlier on in the cars life.)
Again, results are coming out okay. TBN is also okay, but i've only averaged draining out between 3.75-4.25 quarts of oil these days.
Old Jun 23, 2012 | 03:17 PM
E-Ticket Ride's Avatar
Fram filter? Horrible choice, Wix at the minimum, amsoil or k&n if you feeling rich.
I use a napa (wix) myself
Old Jun 23, 2012 | 03:48 PM
stevesg35's Avatar
Fram Xtended Guard review
I know everyone thinks of Fram as the old orange paper filter. Check out this youtube video showing what's in an extended guard (aka Ultra). It's like Toyota builds a base Scion but also builds a Lexus LS460. I get this filter at Walmart when I get the 5-qt Mobil 1 EP
Old Jun 24, 2012 | 12:35 AM
vqsmile's Avatar
^^ I've seen pics of them cut open before and they are definitely worthy of being considered 'upper tier'. You are right though, most folks have a very negative impression of Fram based on their classic cheap orange filters.
R350k5
Oct 1, 2015 08:41 PM
lemmy999
Jul 25, 2015 12:13 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
newbdriver01
Jul 15, 2015 06:10 PM
