brake question for 2007 g35 sport sedan auto
Old Jun 21, 2012 | 09:07 PM
Josuemtz07's Avatar
hey guys im new to this forum
i have a 2007 g35 sedan sport with the auto transmission
and its time already to replace the brake pads but im having a hard trouble trying to find the right brakes
since i have the sport auto version would by g still have the sport brakes or just the standard base brakes?
any input would be helpful
Old Jun 21, 2012 | 09:18 PM
kool_yaar's Avatar
it has the larger sports brakes.. i use posiquiet ceramic and have been very happy with them with no noise or brake dust and great braking as well
Old Jun 21, 2012 | 09:30 PM
Josuemtz07's Avatar
thanks kool_yaar
would it better to just change the rear ones or the front ones first?
Old Jun 22, 2012 | 07:55 AM
Blue Dream's Avatar
I drove ttrank's car solo
Change them both at the same time if they're worn.
Old Jun 22, 2012 | 12:33 PM
vqsmile's Avatar
Originally Posted by kool_yaar
it has the larger sports brakes. ...
Since you're new, and there is often some confusion regarding the 'Sport' brakes on the second generation (V36) G35 sedans, I think in bears mentioning that your car does indeed have the larger 'Sport' version of brakes that correspond with YOUR model year, BUT they are not to be confused with the later model year V36 G37 sedan "Sport' brakes made by Akebono and commonly refereed to as "BBK's".
Old Jun 22, 2012 | 01:47 PM
krazyket's Avatar
I have the 08 G35xS and few months ago I was in the market for new brakes. I did a lot of research and come to find out that your front ones always go before the rear ones. Since they have the most stopping power. I would just get it taken look at from someone if you need to replace the rotors or just pads.
I replaced new rotors and pads for my front wheels and kept stock back brakes. So far I love the performance from the cross drilled rotors.
Let us know what you end up doing!
Old Jun 22, 2012 | 02:28 PM
spoonierme's Avatar
love the way cross drilled rotors look.
Old Jun 22, 2012 | 04:40 PM
kool_yaar's Avatar
Good point made by VQ dont confuse with the g37 bbks also in our cars due to the vdc and brake distribution the rears actually tend to go a bit faster than the fronts as you may find if you search around the forums so recommend changing all four corners for best braking, else inspect the pads life left to decide which ones to replace
Old Jun 23, 2012 | 06:36 PM
Josuemtz07's Avatar
thanks guys for the responses
so even tho my is the 2007 sport auto it would still have the sport brakes that the 2007 6mt has
I called the dealer and for some reason he told me that the 2007 g35 sport that came with auto came with the regular base brakes
he said that the only one that came with the sport brakes was the 6mt and also the 6mt was the only one with the limited slip differential and sport tune suspension
Old Jun 23, 2012 | 09:40 PM
vqsmile's Avatar
Then he's woefully misinformed
http://infinitihelp.com/models/2007/...ifications.php
If you give them your VIN number, they should pull up what it needs.
Old Jun 23, 2012 | 10:57 PM
kool_yaar's Avatar
^whs, its shocking to see service advisers to not know the product they service day in and day out... if you have 2007 G35 Sports auto with rwd then you have the same larger 'sports' brakes as the 6mt
Old Jun 25, 2012 | 03:41 PM
Supremee's Avatar
stupid ****ing people that work at infiniti should know their ****! Im sorry but theres no need to call the dealer. when you order your brakes pick the brakes that correspond with the car and year. its a SPORT model. regardless of 6mt or not. its just a transmission. sport is sport.
I reccomend buying akebono pads. order from tire rack. they ship in like 2 days.
Old Jun 28, 2012 | 01:11 PM
gtbigup01's Avatar
Youre assuming he's talking about an Inf dealer and not a Nissan dealer. I'm changing my rear brake on Saturday and am comparing prices between my Infiniti dealer (95 miles away) and my Nissan dealer (10 miles away), so far $270 from Infiniti. Nissan?? still awaiting a call back, service advisors were busy.
Old Jun 28, 2012 | 02:28 PM
stockae92's Avatar
please keep us posted on the brake pad replacement cost from a nissan dealer
mine are due for replacement.
and i am just wondering, does the V36 G35S brake system shared in any Nissan products?
Old Jul 2, 2012 | 08:25 PM
lifted-d's Avatar
the 13" brakes are not very common as i've found, I have Hawk HP Plus pads all around. the HPS would be mellower and quieter. I would stay far away from oem missan/infiniti pads, total junk sadly
