Eibach Sway Bars vs GT Spec Front Strut Bar
Old Jun 23, 2012 | 11:31 PM
verun's Avatar
I am new this forum and this is my first post. However, i have been religiously been reading this forum and wanted to get advice and opinions. My G35 Journey (non-S) has too much body roll and I want it to be planted to the ground more. However, I do not want to give up ride comfort. This is going to be my first mod to the car. I am deciding between Eibach Sway Bars or GT Spec Front Strut Bar.
Eibach is going to cost me around $325 shipped and with installation will probably cost me a total of $500.
For the GT Spec Front Strut Bar is around $225 and I can install it myself.
Please give your input. I do not care about the aesthetics of the front strut bar. What I am really looking for is better performance for the money being put in.
Old Jun 23, 2012 | 11:56 PM
ChinkyChoy's Avatar
I have both and you will def feel the difference with sways. front strut not so much i did it more for looks lol.
I have hotchkis BTW so i dont know about eibach but i would imagine its about the same
Old Jun 24, 2012 | 12:53 AM
bluedevils95's Avatar
Sway bars helped out alot for me. The strut bar does stiffen it up a littlle more. I noticed it on my G.
Old Jun 24, 2012 | 01:18 AM
kool_yaar's Avatar
like they said the sway bars will help you feel the most difference.
Old Jun 24, 2012 | 07:13 AM
Q8y_drifter's Avatar
A strut bar does a completely different job than a sway bar and therefore the two cannot be compared. Strut bars reduce flexing of the metal in the upper shock towers when the shocks compress. This occurs either in hard cornering or can even be induced under hard braking (to a certain degree). Sways on the other hand reduce the angle of tilt which the car experiences during cornering but have no effect on braking/acceleration.
From your description you obviously want sway bars so go for that.
Old Jun 24, 2012 | 12:31 PM
GXXXV X's Avatar
definitely sway bars! very easy to do yourself with just a socket wrench and jack and jack stands!
Old Jun 24, 2012 | 06:15 PM
verun's Avatar
Thanks for the input. I have decided im going with the sway bar. I had a few questions though.
Since Eibach Sway Bars come with two different settings in the front and three in the back, which configuration do you like the best? I would like to know a detail comparison between the different settings. I am thinking of doing less stiff in the front and the middle one in the rear.
For installation, I have been looking it up and i think I can do it the front sway by myself. However, the rear sway seems to have a mixed input and I am not sure if i should just take it to shop to get it done. What did you guys do?
Old Jun 26, 2012 | 02:33 PM
E-Ticket Ride's Avatar
The first delivers a remarkable improvement. The second, almost nothing other than looks.
Old Jun 26, 2012 | 03:01 PM
apexi957's Avatar
Two different things.
Go sways then strut tower if you have extra money.
jsimonk
Dec 22, 2023 03:49 PM
North NJ G
Steering & Suspension
12
May 27, 2023 01:14 AM
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
