wheel spacer size
Old Jul 18, 2012 | 09:44 PM
Highestrich4's Avatar
wheel spacer size
Hey guys i just bought new stance wheels sc-5ive 20x10 +35 rims for my 07 sedan and I'm looking to see what spacer ill need to run for the front wheels. my tire size is 245/30/20. Will a 15mm spacer work or will i have to do 10mm? please let me know what you think
Old Jul 18, 2012 | 10:51 PM
blnewt's Avatar
Hard to say for sure, one good suggestion is to get a handful of washers (at least enough to put on 3 lugs) and test fit various thickness until you get it just right. 15mm should work, but better to test fit first IMO. Ichiba also makes 17mm spacers if you want just a little more.
Old Jul 19, 2012 | 02:28 PM
VMRWheels's Avatar
I would suggest measuring your clearance and getting the appropriate spacer size.
Old Jul 20, 2012 | 06:56 PM
i ended up not having to swap out my spacer! heres pics the new shoes!
http://www.flickr.com/photos/highestrich4/7607150962/http://www.flickr.com/photos/highestrich4/7607150962/ by http://www.flickr.com/people/highestrich4/, on Flickr
http://www.flickr.com/photos/highestrich4/7607148206/http://www.flickr.com/photos/highestrich4/7607148206/ by http://www.flickr.com/people/highestrich4/, on Flickr
http://www.flickr.com/photos/highestrich4/7607147760/http://www.flickr.com/photos/highestrich4/7607147760/ by http://www.flickr.com/people/highestrich4/, on Flickr
http://www.flickr.com/photos/highestrich4/7607146962/http://www.flickr.com/photos/highestrich4/7607146962/ by http://www.flickr.com/people/highestrich4/, on Flickr
http://www.flickr.com/photos/highestrich4/7607146064/http://www.flickr.com/photos/highestrich4/7607146064/ by http://www.flickr.com/people/highestrich4/, on Flickr
Old Jul 20, 2012 | 08:12 PM
woostar88's Avatar
Vossen? man I love those rims... anyways, so you're saying you didn't need to use spacers?
but if you did, which company, and where did you buy it from? also the spec as well
Old Jul 20, 2012 | 08:25 PM
vqsmile's Avatar
You do realize that these are more than an inch shorter in diameter than the stock size, right? Whereas if you'd gone with a 245/35-20, you'd be pretty much spot on.
Out of curiosity, what size tires are you running for the rears?
Old Jul 20, 2012 | 09:12 PM
Teahyo Kim's Avatar
do you have any rubbing on the fenders?
when you are driving do you have any problem with rubbing on the fender when you are turning, going over bumps or both? what size are you running on the front, the back and the offset? I'm not trying to roll my fender and I'm thinking about dropping it about an inch or so. what ever info you can will help me a lot. thanks for your time. love your ride, it is sick.
Old Jul 21, 2012 | 04:31 AM
My rims are 20x10 +35mm all around. I running a 20mm spacer in front and 25 in rear. I dont have any problems rubbing what so ever. Tire size is 245/30/20 all around also. The reason i did those tires
Is for the stretched flush look. Let me know what you think! Thanks guys
Old Jul 21, 2012 | 06:18 AM
SUMATIC's Avatar
agree with VMRwheels. Do what he says and youll get it perfect.
Old Jul 21, 2012 | 11:26 AM
Xmax's Avatar
Man those are some nice wheels man. I can't wait to see them in person at the next ahemm....Mazda meet
Old Jul 23, 2012 | 01:07 PM
VMRWheels's Avatar
Old Jul 23, 2012 | 05:27 PM
pbabajan's Avatar
nice wheels! not vossen btw to the guy that asked! looks like em tho!
Old Jan 9, 2013 | 10:45 AM
Megazord's Avatar
clean as **** . getting a black set after my retrofit
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
