Dirty speedometer.
Old Jul 21, 2012 | 09:00 PM
Gunnnnzzz's Avatar
Dirty speedometer.
Hey guys... a general question, is there a way to clean the other side of the speedometer?! it looks like its dirty on the other side
Old Jul 21, 2012 | 09:05 PM
kool_yaar's Avatar
Its quite unlikely for it to be dirty from the back side, are you seeing 'spots' that you cant clean? i had similar issue on my acura and as it turns out that the cleaner i used once causes stains on the plastic.
take a pic if you can, if it really is dirty from the inside then youd have to remove the entire cluster to get the plastic cover off.
Old Jul 21, 2012 | 09:11 PM
Gunnnnzzz's Avatar
damn.. u may be right. i used mothers spray on it and it seems like it smeared and stayed there. windex didnt take it off..
Old Jul 21, 2012 | 10:10 PM
mathnerd88's Avatar
The best cleaner I've found is just 70% Ethanol with water if you work in a lab...I use that to clean my LCD screens with coatings on them and it's perfectly fine.
Old Jul 21, 2012 | 10:57 PM
kool_yaar's Avatar
i use a computer monitor spray to clean the lcd and the gauge plastic given how messed it up once.
Old Jul 22, 2012 | 12:00 AM
hurleyguys's Avatar
i had the same thing happen to my temp gauge and clock. the only thing that took it off was some polish and wax.
Old Jul 22, 2012 | 08:20 PM
Gunnnnzzz's Avatar
I used some
Goo gone, good as new now
Old Jul 22, 2012 | 11:50 PM
kool_yaar's Avatar
^ he already cleaned it with some goo gone, it was on the front
Freeman186
Sep 6, 2023 10:07 AM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
vamarris
Sep 26, 2015 12:56 PM
TNRocker
Sep 21, 2015 08:36 AM
