Ticking sound coming from the motor
Old Aug 6, 2012 | 01:19 AM
  #31
Mr. Brett's Avatar
Originally Posted by vqsmile
I highly doubt that. The likelihood of detonation short of engine load (when it's idling) is pretty much unheard of with a modern ecu and fuel injection.
Unless you've got a lot of carbon build-up and deposits in your engine.
Old Aug 6, 2012 | 03:32 PM
  #32
Sweet Lew's Avatar
Originally Posted by jomamahama
sounds like a normally noisy valvetrain. I doubt if it's something that necessitates getting into and replacing parts unless it gets worse and there seems be an effect on the car. Ignore the other guy, the welds on your manifold will hold just fine. But if washers start pinging off of your floorpan, pull over and get a tow.
That's what I'm thinking too...
Thanks everyone for the input!
Old Aug 7, 2012 | 09:15 PM
  #33
Ketchup83se01's Avatar
check your oil level, might be low on oil,the vq35's that burnt oil sounded like that when low on oil, and who cares if your dealer changed it, check it yourself man god dam it
Old Aug 8, 2012 | 08:17 AM
  #34
Sweet Lew's Avatar
OK OK! JEEEEEZ! I'll check it tomorrow morning before I leave for work. So lets ASSume the motor is burning oil, then what happens? What does the ITB say?
Old Aug 8, 2012 | 12:11 PM
  #35
Mr. Brett's Avatar
If the motor is burning oil, there's not much you can do other than monitor it and make sure it doesn't get low.
Old Aug 8, 2012 | 04:46 PM
  #36
RedBaronK's Avatar
I had this issue. It was a pulley going bad, so the dealer replaced the pulley and belt for free
Old Aug 8, 2012 | 08:47 PM
  #37
Sweet Lew's Avatar
Do you know which pulley it was?
So there are all sorts of possibilities of what it could be. Since the car is still under full factory warranty, I will bring it in for them to look at it. Will let you all know tomorrow about the oil level.
Thanks everyone for your input!
Lew
Old Aug 8, 2012 | 09:12 PM
  #38
Anton_Chigurh's Avatar
nothing happens..just make sure it doesn't get low and fill up when needed
Old Aug 8, 2012 | 09:16 PM
  #39
RedBaronK's Avatar
Lew
Ill if I can dig up my receipt
Old Aug 9, 2012 | 08:23 AM
  #40
Sweet Lew's Avatar
Oil level is fine.
Old Aug 11, 2012 | 07:15 PM
  #41
rollaspeed1's Avatar
I had that after I brought the car back from the track. Dealer replaced the heater and the ticking went away
Old Aug 13, 2012 | 10:55 AM
  #42
johnnyzee's Avatar
what heater (what part of it)?
Old Aug 14, 2012 | 11:14 AM
  #43
Sweet Lew's Avatar
If there is silicone deposits in the heater core then you will hear a ticking sound coming from the dash. There is a TSB on it. I don't have that issue.
I submitted the videos to the Service Department on Friday and have yet to hear back (not surprised). I will make an appointment to drop the car off or just wait for the next oil change.
Old Sep 11, 2012 | 08:38 AM
  #44
Sweet Lew's Avatar
Wanted to provide an update. Car has been dropped off at the dealer to have faulty TPM sensors replaced while the car is still under warranty. They will give a listen to the car as well. I will post up what they find. My money is on "It's Normal".
Old Sep 11, 2012 | 11:45 AM
  #45
Sweet Lew's Avatar
Received the call from the dealer....
It's NORMAL!!
Trying to find out what exactly the noise is though.
