Transmission Flush Interval
Anymore, and depending on your car's previous tranny service history, it seems the dealers are just recommending a "refresh" rather than a flush, which is just a drain and refill of the oil pan (around 4-5 quarts).
a flush was already done at around 60k miles. currently around 90k miles and dealer advises the fluid is burnt. should i do flush or just drain/refill? dealer says flush, so im curious on others' thoughts. thanks!
Fluid burnt after 30k miles? Have you been racing or tow a lot? Usually fluid should last around 50k-60k miles no problem under normal conditions. The 30k mile service interval was meant for people who push the car hard and race a lot. Nissan calls it "severe" service interval.
I still recommend a drain and refill. Flushing may damage some transmission components according to the Nissan bulletin.
Drain and fill is easy to DIY, that way you know something is happening.
