road noise/vibration ONLY at 58-60...
Old Oct 5, 2012 | 12:38 AM
RedBaronK's Avatar
Any ideas? Its not the tire, cause I have the same issue despite replacing all tires to a different brand.
Alignment checks out.
All brake pads have a lot of life left... BUT I hear constant squealing while breaking from the front left. Dealer claims its scorched rotor.. but I had the TSB done already and replaced rotors while back, and installed the shield behind rotor. Another dealer said brake pads needed replacing... total BS cause I can visually inspect the pad thickness ...its fine.
CV joints r fine, I made turns in a parking lot and did not hear any sounds.
What else could be causing this???
Old Oct 5, 2012 | 01:35 AM
Anton_Chigurh's Avatar
does it come and go? ( that's what my vibration does..had one for 15K miles)
Wheel bearings, compression bushings?
Old Oct 5, 2012 | 01:45 AM
RedBaronK's Avatar
Yeah its only between exactly 58-60... outside those ranges, whether its below or over, no more vibration....
Old Oct 5, 2012 | 01:53 AM
strange...well mine is strange as well so who knows
Old Oct 5, 2012 | 02:02 AM
kool_yaar's Avatar
sounds like out of balance tires to me
Old Oct 5, 2012 | 02:06 AM
RedBaronK's Avatar
Its not... both sets of tires balanced at two different places multiple times.. same issue persists.
Old Oct 5, 2012 | 07:39 AM
mishmosh's Avatar
Were they roadforce balanced with a Hunter machine? Still could be a bent rim.
Old Oct 5, 2012 | 10:56 AM
krazyket's Avatar
I have had my friends tell me that the car vibrates on the highway at high speeds. But, when I drive it I have yet to notice it. They may notice it because they drive Audi S4 & X5 //M.
Old Oct 5, 2012 | 11:53 AM
soundmike's Avatar
^ This.
It has to be properly roadforce balanced with a Hunter machine. And make sure they do it properly. Many times i went to have something roadforce balanced and they fail to activate the roller.
Old Oct 5, 2012 | 01:12 PM
kool_yaar's Avatar
like the other poster responded just because it was balanced properly multiple times does not mean they are good i have had this issue too on my previous cars with many places, spending a little extra for the road force was worth it 3 out of 4 times to fix the problem. One time when they tried to balance it and could not they took the tire off and tested the rim to find that the rim was slightly bent/damaged that was not visible to the naked eye until we knew where to look for it.
it might not solve the problem for you its worth a try imo, other than that its your call
Old Oct 5, 2012 | 01:55 PM
RedBaronK's Avatar
I remember seeing during my last balance and rotation road force somewhere on the paperwork... ill see if I can dig it out.
As for the bent rim... anyway of checking it my self? Maybe a tape measure or something of the diameter across the rims perhaps?
Old Oct 5, 2012 | 01:59 PM
VMRWheels's Avatar
Road Force balancing is a must! I want to say that's probably where the vibration is coming from. A tire can be balanced but that does not necessarily mean that you won't ever experience vibrations due to feedback from the road and whatnot. Tires, just like wheels, are not perfectly round, so the Road Force machine will match the high and low points of the tire and wheel to the best of its ability to make sure that you won't get any vibrations.
Old Oct 5, 2012 | 04:26 PM
soundmike's Avatar
RedBaron, i'm curious, would you happen to have a pic or know how many wheel weights you have on the wheels? Total the stick-on's along with the clip-ons (usually found on the back of the rim.)
There's a theoretical limit to how much weight is added, if this was truly roadforce balanced.
Old Oct 6, 2012 | 10:55 AM
vqsmile's Avatar
I too think that the tire balance issue is most likely to blame, but just as a quick check, I'd want to eliminate the drive train as a possibility. Specifically, does it still make this sound when the drive train is 'unloaded' ?
Old Oct 6, 2012 | 12:40 PM
RedBaronK's Avatar
Hmm I can take a pic and upload to see how many weights r on it...
VQ when u say unloaded, ur referring to coasting the car down the road without any gas being applied right? If so, when I let my foot off the gas from lets say 80mph, as it slows down to 60-58mph the vibration comes back
