Serpentine/drive belts.
Old Oct 5, 2012 | 08:19 AM
Boy_wonder's Avatar
How often does 2008+ G35xs owners change their Serpentine belts?? Thinking about doing mine today I have 50k miles on the car.
Old Oct 5, 2012 | 10:07 AM
Ye_Budyy's Avatar
You can change it whenever you want...50k miles is good...do they make any noises at all..?
Old Oct 5, 2012 | 10:14 AM
Boy_wonder's Avatar
Actually they don't at all but when I went to get a oil change and tire rotated they ask me to change the air filters and belt when I get the chance. I did two new k&n
Filters and ordered a new belt at the shop. I guess I would be doing some good forecasting
Old Oct 5, 2012 | 10:16 AM
Ye_Budyy's Avatar
Well you can never go wrong with taking precaution haha
Old Oct 5, 2012 | 12:43 PM
GXXXV X's Avatar
would a high pitch squeaking after cold start be because i need to change my belt?
Old Oct 5, 2012 | 01:02 PM
kool_yaar's Avatar
fyi there is only one belt on the V36 to replace and if you read in the diy section most last quite some time while others have snapped early mainly due to the auto tensioner not acting properly. Best way is to inspect the belt visually for cracks and crumbling.
Old Oct 5, 2012 | 01:23 PM
Ye_Budyy's Avatar
Ya most of the time....or this can mean that the belt is a bit lose...just look at the belt closely (from the inside) to see if there are cracks or signs in wear
Old Oct 5, 2012 | 10:21 PM
RemmyZero's Avatar
You can easily replace the belt in ~15 minutes in good weather. just check out my DIY and save yourself some dough!
https://g35driver.com/forums/v36-diy...bably-g37.html
Old Oct 6, 2012 | 01:26 AM
vqsmile's Avatar
Originally Posted by kool_yaar
... most last quite some time
... Best way is to inspect the belt visually for cracks and crumbling.
+1 nuff said!
Old Oct 9, 2012 | 07:05 AM
stevesg35's Avatar
My Infiniti mechanic told me the new generation serpentine belt in the G is made with EPDM - you can google it - and as a practical matter they could probably be lifetime. As it's a cheap maintenance, you can do it anytime, but the mechanic told me it's virtually certain the belt would last 100k or more. I'm going to do every 60k since it's cheap. I think he also said with the EPDM belt it's not really the visual inspection for cracks that matter, but I can't remember what did.
Old Oct 9, 2012 | 07:39 AM
Boy_wonder's Avatar
Get outta here that's some good info. Lol
Old Oct 9, 2012 | 09:45 AM
imRACERX's Avatar
can someone guide me to where i can find instructions on replacing the crank shaft serpentene belt? thanks John
Old Oct 9, 2012 | 10:01 AM
vqsmile's Avatar
you can get the FSM here: http://x.infinitihelp.com/forum/local_links.php?catid=3
Old Oct 10, 2012 | 08:42 PM
imRACERX's Avatar
anywhere else? i dont want to register and all i need to know is where the tentioner is! Thanks John
Old Oct 10, 2012 | 08:58 PM
vqsmile's Avatar
... all i need to know is where the tensioner is! ...
I can't imagine it's all that hard to find.
