Roof spoiler
Old Oct 11, 2012 | 09:19 PM
Boy_wonder's Avatar
Roof spoiler
what is the best way to attach my newly panted roof spoiler. I live in Boston MA #GoPats my friend and I tried to use two sided tape but it seem not to stick well idk if it was due to the back glass being to cold it is about 58 degrees outside. what is the best option to add it and have a peace of mind that no one can rip it off, i would rather it brake first
Old Oct 11, 2012 | 09:30 PM
bluedevils95's Avatar
Get the 3m tape that sticks better and then put some weight on top of it.
Old Oct 11, 2012 | 09:57 PM
Boy_wonder's Avatar
do you have a model number to reference?
Old Oct 12, 2012 | 12:19 AM
bat6wc's Avatar
i recommend 3+ dabs of clear silicone adhesive to really hold it.
Old Oct 12, 2012 | 12:51 AM
I have the thin 3m tape which one side came up. If i put the thicker 3m it would have stayed. But i don't buy the cheap stuff. I will get the thick one when i have time to fix it then putting some weight on it to make sure it stays on.
Old Oct 12, 2012 | 01:16 PM
bwalsh's Avatar
I have the stillen roof spoiler and had no luck stickin that Fn thing down until i tried this 3M windshield stuff. I bought mine at Auto Zone so im sure pretty much every place will have it but to make the story short that thing is not coming off! not that i have gone 150mph in my car but if i did it wouldnt come off! i think if i tried to get it off the whole windshield would come with it! good luck and try it out!
Old Oct 12, 2012 | 02:45 PM
VMRWheels's Avatar
I've had good success with simple 3M automotive tape from Auto Zone. If the surface is prepped correctly you shouldn't have an issue. I would recommend cleaning the area thoroughly, cleaning the spoiler thoroughly, applying long strips, and keeping even pressure while you are sticking it.
Old Oct 12, 2012 | 04:22 PM
saywat?'s Avatar
i have the stillen roof spoiler. the instructions say to put 2 layers of tape on top and bottom and 1 layer on the sides. the goal is to have the tape protrude a bit because of the indented area where the tape is added. i use the cheaper 3m tape from china thats sold on ebay. ive always used that lol. works for me. its thinner than the store bought 3m tape so i usually end up putting an extra layer to compensate. not sure if temp is an issue in ur area since i dont deal with that stuff but its usually recoommended to do things like this is warm daytime temps
Old Oct 12, 2012 | 05:21 PM
VMRWheels's Avatar
^I would say warm would be best too, although I've never tried it in in a colder environment.
Old Oct 12, 2012 | 06:13 PM
CRV_33's Avatar
Im just reinforcing what us being said above. Wait until its at least 75+ degrees. Plus make sure you prep the surface before you mount the spoiler with rubbing alcohol. Also if you can apply some pressure when mounting the spoiler by stacking something like weights, textbooks, or even clamps if possible.
This is what you'll need to look for at AutoZone. Just take your time and be patient. I put a roof spoiler on my old car and it survived Minnesota's epic winter blizzards. In fact I'm having a hard time taking it off since I'm trying to part the car out. Lol
Old Oct 12, 2012 | 06:30 PM
smokinn85's Avatar
Definitely need warmer temperature. I added a bead of clear silicone down the center between the tapes. Been through the automatic car wash a few times without issue.
Old Oct 13, 2012 | 09:17 AM
Boy_wonder's Avatar
Thank you all I love all the feed back. On Monday it will be 70+ and I think that is going to be my last chance before it gets way to cold I am going to leave work early and get it done. Does anyone have an idea on how long I should leave pressure on it or how long it should sit before I drive around and everything? Car wash ect.
Old Oct 14, 2012 | 12:04 AM
saywat?'s Avatar
Lol at the "put some weight on it". Jus tape it down with masking tape.
Old Oct 14, 2012 | 12:09 AM
CRV_33's Avatar
Better than your suggestion to stick two layers of tape to each other.
Old Oct 14, 2012 | 12:13 AM
saywat?'s Avatar
^wat a freaking idiot. That's the instructions from stillen.
