HIDs flickering?
HIDs flickering?
So when the headlights first turn on. They flicker sometimes for the first 3-4 min then stop. They also do it when i hit bumps. But not all the time. Is one about to go?
Problem is i can't tell which one. How long do these usually last? Car is an 07 with 80K on.
Hard to replace on my own? It's only about 3-4 flickers in those 3-4 min
After I changed my bulbs, the bouncing started, but very slightly. They also "bounce" during idle since the car is vibrating slightly but goes away. I have a feeling that your problem isn't really a problem at all, just a normal characteristic.
I'm not sure if I have the same problem, but mine isn't really flickering. My problem is that the bulb is "dancing" in the housing when I go over bumps. I doubt both your ballasts are going out at the same time like that. Have you changed your bulbs recently?
FS[NorEast]: FOR SALE: 2007 G35X (82K miles, Asking $12,000)
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
