Gauging interest in having an understated trunk spoiler created for V36 sedan 07-13
I am in discussions with a first class company to develop an understated spoiler for the G35/37 sedan, and I would like to see how much interest there is out there for this product before we make the tooling. I was involved in the design of this car and we never got the spoiler quite right. I think a subtle lip spoiler that covers or replaces the chrome accent piece would finish the car nicely. If there is enough interest, we will bring it to market, so please spread the word to your G friends and reply to this thread.
Here is the idea:
+ Covers or replaces the silver finisher on the trunk.
+ More understated & coordinated with the trunk design elements than other spoilers:
+ Mounting- NO DRILLING -double stick tape if we pursue an overlay style. Using factory fasteners of silver trim + double stick tape on outboard ends if we replace factory silver trim.
+ Construction and fitment would be first rate. Likely carbon, but also considering fiberglass and polyurethane.
Here is my assessment of the existing spoilers. None of the comments are meant to criticize, just to help explain how this new spoiler will differ. If I am missing any, please let me know.
Factory Option:
+The only spoiler that replaces the silver trunk finisher, to provide a clean integrated look with polyurethane.
+ Rear vertical surface matches the arc of the factory trunk in the side view
- Style is a table top, not a lip style, so it looks heavy from the top view
- Size is good for coupe, but too large from our perspective for the sedan
- L&R ends are strange. They end between trunk edge and character lines, creating an awkward un-integrated appearance at the corners.
- Does not incorporate character lines in top of trunk, or line up with taillights in rear
Carbon Signal:
+ Generally nice shape with lip across spoiler. Follows arced vertical surfaces of the trunk
+ Rear view shows arc near L&R ends, but flattens out in the center
- Large, with duckbill style shape that rises from trunk lid quickly in side view
Autokits X:
+ Lip spoiler shape is good. Lip is in the center section only
- Rear vertical surface is flat, which doesnt match the arc of the trunk. This combined with the thick center section makes the spoiler look heavy from the rear view.
- Spoiler material is thick, which negatively affects the view out the rear view camera lens.
- Larger than we would like for the sedan.
Euro or T5i:
- Looks like an afterthought, as it doesnt cover the chrome piece
Thanks. Please pass the word on and let us know what you think.
Here is the idea:
Shape-A gentle ark upward from the front to back edge in side view, with a rear lip. Similar to Carbon Signal, but with a more gentle slope (less duck bill).
Size-Small to get understated OE look-between M3 size & Factory option while just covering the silver trunk finisher.
Width-as wide as the trunk to provide wide image and allow the two outboard character lines on the top of the trunk to carry into the top surface of the spoiler.
Rear vertical surface of spoiler will follow the smooth arc of the trunk in side view
Rear edge of spoiler should follow the same arc as the trunk when looking from above
Top edge of the spoiler in rear view should have a slight arc from L-R, to match trunk
Bottom edge of the spoiler in rear view should cover chrome finisher, and line up with top edge of taillight at ends.
+ Camera-Rear vertical surface should be thin so rear camera image isnt narrowed Size-Small to get understated OE look-between M3 size & Factory option while just covering the silver trunk finisher.
Factory Option:
Carbon Signal:
Autokits X:
Euro or T5i:
BTW OP, see my reply on G37, sounds like a nice idea you're planning. I love my oem lip spoiler but it's not to say it can't be improved upon
+1 Don't make it too curvy. It will look cheap.
Thanks everyone for your interest. I will keep all of you informed as the project progresses. Please keep the replies of interest going. The more interest I can convey, the better chance we have of getting this developed.
Blnewt, if we make an overlay, it will be attached with 100% 3M tape. If we replace the chrome accent piece, it will be attached in the middle with the factory hardware from the chrome piece, and we will attache the ends with 3M tape. We won't require drilling any holes.
Chumacher, it won't be too curvy. Don't worry, our whole intent is to make this look understated and integrated, as if the factory did it, which was not the case with the dealer accessory.
Stochae92, thanks for buying the MT. I wish more people did. It is a great combo and we had to fight to keep it alive on the 2nd gen because the dealers didn't want to stock it even though it had a faster turn rate than the AT versions.
Thanks everyone for your passion. I loved developing this car. The team I worked with at Nissan worked very hard to make this car the best it could be, and it is great to see this community taking the car that extra mile.
