Whistle noise in cold weather
Old Jan 23, 2013 | 10:45 AM
Glaz's Avatar
I have a 2008 G35x Automatic. It's been very cold recently and when i first start the car it makes a high pitch whistle noise for about 15min or so..then it's gone.
It's not very loud..I can't hear it from inside the car...only when parked and started and im standing next to it.
Did any of you ever experience this?
Thanks for the help
Old Jan 23, 2013 | 11:07 AM
mathnerd88's Avatar
No idea...could it be your belt? They usually make chirping/whistling noises when they're going bad.
Plus it is indeed cold out so it could make your serpentine belt act weird, since cold does harden rubber. I would start by checking your belt for any cracks or tears. It is easy to spot.
Old Jan 23, 2013 | 11:47 AM
nogoodname's Avatar
It's normal when it's bitter cold. Usually my alternator makes that noise for a few minutes.
Old Jan 23, 2013 | 02:25 PM
willdogs's Avatar
my belt has been making noise since the weather got really cold. It's at 50k miles so due for a change anyway. Part on order with Phil now..
Old Jan 23, 2013 | 05:36 PM
mathnerd88's Avatar
I don't think alternators are supposed to make noises like that...Are you sure it isn't the belt chirping as it's turning the pulleys of the alternator? Your bearings might be going bad in that case.
Old Jan 23, 2013 | 05:41 PM
Supremee's Avatar
mine does the same. i guess its common for the cold. i have an 07 g
Old Jan 23, 2013 | 06:29 PM
Deepdiver's Avatar
dats the vtec warming up yo!
Old Jan 28, 2013 | 10:19 AM
emitch22's Avatar
Mine has started that whistling noise to but I'm 99% sure its just the belt on mine. How much does it cost to get the belt changed anyway?
Old Jan 28, 2013 | 11:02 AM
Glaz's Avatar
So i called the dealer and my "Service rep" says it's the belt..the cold makes it dry or something... Nothing to worry about.
Next visit i'll have the belt changed if anything
Old Jan 28, 2013 | 11:49 AM
hyukki's Avatar
It's because the rubber gets hard when it's cold. Also probably bc the rubber has dried out over time
Check if your belt needs replacement.
Changing the belt is extremely simple. Only need a breaker bar (with smaller joint, cheaper bars have bigger joints that won't fit in the space in our cars) or a serpentine belt tool from harbor freight tools.It should take like 30 minutes max.
Old Jan 28, 2013 | 02:07 PM
kool_yaar's Avatar
^whs, there is a detailed DIY on here making this a ~$40 and 30min 'repair'
Old Jan 28, 2013 | 02:10 PM
Zomorg3's Avatar
Does it happen when you drive too because if you any intakes on the car, some of them will whistle while you are driving at certain RPM's
Old Feb 1, 2013 | 02:41 PM
blues3531's Avatar
I have a coupe that does the same thing and its def not the belts. I've had both the serpentine and AC belts changed recently they're practically brand new and it still does it.
Old Feb 1, 2013 | 10:25 PM
kool_yaar's Avatar
^ if you narrow down the sound to be coming form the belt area then check the tension on the belts
Old Feb 1, 2013 | 11:14 PM
Scrildo's Avatar
Mine does the same too its like a whistling humming noise from what sounds like the drivers side firewall area and it only does it when the car is cold goes away when its warm. I have an 06 sedan 6mt.
