Gas smell in cabin
Old Feb 1, 2013 | 09:31 AM
pattyballs's Avatar
Gas smell in cabin
Hey guys,
I have been having this issue ever since to cold weather set in here in NY. Whenever i come to a stop in the car i have had this fairly strong smell of gas. Havent had much time to look into it, but was hoping that someone can point me in a good direction to start. I was also thinking that there is a possibility that since the air is denser the cars computer is therefore giving more gas to meet the proper air/fuel ratio. Again, if anyone can give some advice or has had the same problem, any help will be much obliged.
Old Feb 1, 2013 | 10:34 AM
Peoria35sedan's Avatar
Pull your rear seat bottom out and look, the tank is right under the seat. It will take all of 5 mins to confirm if you have a leak.
Old Feb 1, 2013 | 11:02 AM
pattyballs's Avatar
So once i pull the seat i gues i would just look for any stains or anything?
Old Feb 1, 2013 | 11:04 AM
vdoh8687's Avatar
Could also be an exhaust leak, that would smell like gas especially if it was before the cat. My moms Highlander had this problem and the exhaust had a few holes before the cat.
Old Feb 1, 2013 | 11:23 AM
Look at the access panel on the top of the tank where the lines go in, rubber seal may be leaking. You might want to drive it without the seat in to see if it's worse.
You'd think he would hear an exhaust leak, but maybe.
Old Feb 1, 2013 | 11:34 AM
pattyballs's Avatar
I will deffinitely try that and check everything with the tank. As far as an exhaust leak, i am not positive but it does make a hissing type noise when changing gears and is minimally louder but i do not have any codes or anything leading to exhaust leak. Will give the exhaust a once over tho.
Old Feb 1, 2013 | 11:36 AM
vdoh8687's Avatar
The one on the Highlander did not make noise at first, but yes if is an exhaust leak it will eventually get worse and make noise.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Blue Dream
Dec 5, 2015 10:56 AM
hrdwirk1
Oct 2, 2015 06:34 PM
Hogbone
Sep 28, 2015 06:44 PM
