Headlight problem!
Old Feb 6, 2013 | 12:21 AM
Jaywo33's Avatar
Headlight problem!
So today I noticed my driver side headlight was out on my 07 g35s sedan. 1st thing I do is swapped the bulbs thinking the bulb went bad. But no, bulb is fine. Next I checked the fuses in the fuse box that is left of the battery, and those are all good. Last I remove the headlights and swap the ballasts, and again it is not the ballast. I'm out of ideas, anyone know where to go next.
Old Feb 6, 2013 | 04:06 AM
djfarhan's Avatar
are all the lights out? just the low bean and highbeams?
Old Feb 6, 2013 | 08:45 AM
mathnerd88's Avatar
Maybe check out your IPDM?
Old Feb 6, 2013 | 12:01 PM
Jaywo33's Avatar
Just the low/high beam is out on the driver side. I'm going to go over the ipdm one more time but pretty sure everything looked good in there. Just wondering if I was missing something. And I am getting an "!" Inside a triangle on the dash, but I have nothing to read it. And live in vail co, so I'm 110 miles away from dealer.
Old Feb 10, 2013 | 08:02 PM
M3Loco's Avatar
Mine had the same problem 2 months ago. Ordered theretrofitsource kit and solved the problem. Before that, I just ordered an OEM (used) ballast and it didn't solve the problem. My mechanic replaced both ballasts and wiring and it solved it all.
wonderizm
Sep 24, 2015 03:09 AM
derres
Aug 28, 2015 03:27 PM
youngdip631
Lighting
Aug 27, 2015 03:49 PM
Mick_L
Aug 25, 2015 04:27 PM
attarday
Jul 15, 2015 04:03 PM
