Hit 100000 Miles...Recommended Maintenance?
Old Feb 10, 2013 | 12:53 PM
vqsmile's Avatar
Originally Posted by mishmosh
30K trans oil change is for "premium maintenance", ie. optional. I think every 30k tranny oil change is way overkill personally.
If it were a complete fluid change that was being performed then I would agree with you, and I do not know whether or not that is actually what the Premium schedule calls for, but if it's just a partial fluid 'refresh' that's being done, it's not that extreme.
.02
Old Feb 11, 2013 | 10:57 AM
vdoh8687's Avatar
Originally Posted by mathnerd88
It really depends on what you're doing. Infiniti says premium maintenance is for all kinds of drivers, whether you tow, track, or drive on a lot of dirt roads.
30k is recommended for drivers who push their cars hard, but I would say you should at least change it at 50-60k for normal daily driving.
I would agree 30k is probably overkill, but they can just look at it and see if it needs to be done. However, by 100k it is most likely going to be completely shot so I would not wait that long. I changed the radiator on my dads car the other day, 100k miles, and the radiator fluid that came out looked like hot chocolate...needless to say I will now ask to have mine changed at the next oil change lol.
Old Apr 6, 2013 | 05:17 PM
Z 2 G's Avatar
I have surpassed 100k as well..
My clutch makes this horrible grinding noise when shifting.
It's really bad when starting the car, but isn't as noticeable after it's been driven for a couple minutes. When i push the clutch in it makes this clutter noise similar to a blender. It stops to do it when I put it in 5th at a stand still. Anyone know what this could be? I have replaced my fluids recently.
Also, my car makes this clunk noise when going slowly over bumps or turning. Seems to come from the front left. I got my Bushings replaced. I think i found the problem awhile back but forget what it was called.
Old Aug 27, 2017 | 09:16 PM
Wes Beecham's Avatar
Be careful
If you haven't changed your tranny fluid in a long time and flush the system you take the risk of the transmission slipping. I've done it twice. Take it to someone that warranties their work so if it breaks it's on them
Old Aug 28, 2017 | 06:10 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
That's really not an issue anymore due to better detergents in automatics, happened a lot back in the days of the carburetor however and the old stigma persists.
Anything newer than DEX III won't have the coagulation issues from age/heat, I think the G recommends Matic-S which DEFINITELY wouldn't have that problem. Only way it could be a problem is if someone got a flush done and replaced the factory fluid with something like ATF+2 or lessor, or DEX III and just ran the bejesus out of it for like 150k miles between interval.
The dealership price on a tranny flush is only about $80 and you know it's getting done properly so...
Old Aug 28, 2017 | 08:16 PM
Be careful
It really wasn't a stigma. It happened. It was just a heads up type of thing. But it was real life and it wasn't a carburetor motor and it was dextron 3. But good luck with not doing it on a regular basis. Trust the detergents bro
Old Aug 28, 2017 | 09:07 PM
cleric670's Avatar
BANNED!!!
No I absolutely recommend changing fluids at recommended intervals but it's SUPER rare to have any transmission related issues due to a flush on modern vehicles. Sediment and deposits can still happen if the interval is just flat out ignored for hundreds of thousands of miles OR in applications where heat is an issue (track or tow) but the detergents are so much stronger and the breakdown from heat is so much less (modern efficient design and TCM's built to protect against overheat) that valve body clogging is very much a thing of the past. The only real issue I see nowadays from ignoring the maintenance intervals is erosion of the valve body and torque converters due to high speed/pressure contaminants slowly removing material at various different points that have high hydraulic thrust.
EDIT: Just saw you said it was DEX III, yes that's old technology and definitely shouldn't be used in a G transmission, or any modern transmission unless recommended by the manufacturer, but I'm pretty sure it wasn't recommended in anything newer than 15 years old so...
Old Aug 28, 2017 | 09:53 PM
G2B35AGN's Avatar
So what are your thoughts on a low mileage (now 30K) eleven year old 2006 5AT just bought in March. My thinking was drain and fill just due to age of fluids; dealer service records show only recommended service at mileage intervals, not time. You would do a flush?
Old Sep 3, 2017 | 05:20 PM
cleric670's Avatar
BANNED!!!
I would replace every single fluid in the vehicle. Everything breaks down due to age.
Old Sep 3, 2017 | 05:55 PM
G2B35AGN's Avatar
That's what I thought too and that's what I did.
Old Sep 10, 2017 | 03:19 PM
SofaKingAzn's Avatar
Other than fluids. hardware I would say maybe spark plugs and thermostat! I'm not sure what the interval for spark plugs are but it is an relatively easy job and I got mine replaced at about 75k miles. Thermostat I say you should replace it because mine just crapped out 96k miles :/ I just pulled it out today and it was indeed the thermostat failing closed causing over heating issues.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
DRG35R
Sep 16, 2015 05:33 AM
