Is my G35 in theft danger?
Old Apr 9, 2013 | 10:24 AM
vqsmile's Avatar
Originally Posted by terrycs
Looks like a poor attempt using pliers to me?
Ehhh, IMHO, there's way too many strokes involved. Someone would have had to open and close the pliers dozens and dozens of times; and not a single scratch on the adjoining paint. Vandals are usually lazier than that..
Also, notice all the tiny little pit marks on the lower sides, but the top side is completely clean (including the paint). The way pretty much any gnawing animal bites is to 'set' their bottom teeth like an anchor, and then chomp down with their upper teeth in a slicing or scoring fashion, all done repeatedly at hyperactive speed; which is all consisitent with those markings. It looks like many many tiny repeated slices, starting from the upper side and ending toward the lower side.
Maybe you guys will think me crazy, but I've had rats get at/into vehicles before. You can't imagine the amount of damage the litle bastards can do; and it's often completely random . . . like WTH did you chew the wires from the MAF in half for? ...Or the vacuum lines? . . . and why bother to carve out the side of the fan shroud when you could just crawl around it? Just crazy random stuff would be destroyed.
Old Apr 9, 2013 | 12:10 PM
vdoh8687's Avatar
Probably just a jerk trying to mess up your car, but it is easy to break into our cars by messing with the door handle and taking advantage of the auto roll down key feature: https://g35driver.com/forums/g35-sed...roll-down.html
Old Apr 9, 2013 | 12:24 PM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
I agree with some of the others, very sarcastic answer to someone's real problem, we've all needed some information on a vehicle at one point in our life, so it's nice to see that needless responses pointed out.... now, to your real issue, what paint code is your vehicle? I did this based of K52 paint from the picture....
Outer Escutcheon LH side - 80646-JU61A G35driver price $28.86
Outer Door Handle LH side - 80640-JU61A G35driver price $127.72
these are pre-painted parts, so they will match your vehicle, but will need to know the exact paint code
~phil~
Old Apr 9, 2013 | 02:17 PM
blnewt's Avatar
~phil~
Nice job Phil
Old Apr 9, 2013 | 02:23 PM
bluedevils95's Avatar
Might be cheaper to get the door handle form the junk yard and just repaint it yourself.
Where did this happen
Old Apr 10, 2013 | 07:32 PM
Shurik355's Avatar
can't believe they didn't scratch the door trying to pry on that handle like that. That is pretty weird how the handle is damaged.
Those door handles are not easy to change, not the easiest handles to do. In order to replace the handle the whole door has to be taken apart; trim panel, water shield, door window/glass, belt molding, then the handle. The handle has two sockets for that button, that need to be disconnected on the inside.
I'd say it's about 1.5-3.0 labor hours to replace the handle, probably around $150 if the shop does it for you. . And if you buy new handles, they come pre-painted like Phil said. So around $250-300 for the whole thing. Expensive repair if you ask me. But if you do it yourself, would be a lot cheaper, but you might brake stuff if not experienced enough, so be careful.
Old Apr 10, 2013 | 08:53 PM
castigo's Avatar
Hay I got into my 2007 g35 s in 2 min after locking my key in the car of course the battery was dead all I needed was a flat head screw driver and slim jim it took long to find the slim jim then it took to get in the car the alarm went off course so if there is security hop fully they'll here it go off I don't know what to tell you but it's not hard to get in the car .
chinee
Jun 10, 2024 07:48 PM
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
laksjd84
Jul 24, 2015 05:12 PM
