Engine "tick" - need help. Video
Old Apr 10, 2013 | 04:10 PM
jasonmolinari's Avatar
I recently noticed an engine "ticking" sound on my 08 G35.
this is only noticeable from outside the car, so it isn't very loud. It does seem related to engine RPM.
Seems unrelated to engine temp.
This could be normal, i've just never noticed it until a month or 2 ago.
If anyone feels like listening the video/audio is here:
Seems to be coming from front left side of engine (when looking at the engine from the front of the car).
Any help appreciated. I would bring it to the dealer, but they want $130 just to listen to it.
thanks!
Old Apr 10, 2013 | 06:59 PM
MikeJones916's Avatar
My 07' Journey makes the exact same noise.
Never thought of it as anything until now.
_Michael
Old Apr 10, 2013 | 09:38 PM
Interesting.
As i said, it could be completely normal, and i just never noticed it before...
Old Apr 10, 2013 | 10:53 PM
vqsmile's Avatar
The frequency of it is what's puzzling to me. For it to be related to engine rpm, but at such an apparently slower repetition cycle is odd. If it were at 2 or 3 times that frequency, I'd wonder about an exhaust manifold leak, or possible a loose spark plug, since it almost sounds like a tiny shot of compressed air. All the individual accessory pulley wheels turn over at a greater frequency that that as well, so then I wondered if the fan belt has a bump or defect that only makes noise once every pass around. Seems like any vacuum valve or whatever would also cycle quicker than that.
Old Apr 10, 2013 | 11:19 PM
It does seemed timed with the belt going around. Almost like its bumping something or rubbing something.
Old Apr 11, 2013 | 11:15 AM
Anton_Chigurh's Avatar
thanks!
You don't have a local mechanic? If you don't you need to find one. Screw the dealership and their overpriced services
Old Apr 11, 2013 | 12:29 PM
emorehs's Avatar
Two things in my mind. AC compressor/pulley or your belt. Try this let someone turn your AC on and off while your in the engine bay (listening) If you hear a quick squeak then it's the AC compressor/pulley. (There's a thread here ill find it and post it later )
Old Apr 11, 2013 | 02:17 PM
Wannabe6MT's Avatar
-MN G Crew-
Or just befriend your dealer like me haha.
I dont know if its normal. I'd have to listen to mine. Mine used to tick audibly but I dont notice it anymore.
Old Apr 11, 2013 | 04:14 PM
Already did this. The sound is unaffected by turning the AC on and off...
I'll try to advance the belt by hand and see/feel if i there is anything abnormal.
Old Apr 11, 2013 | 08:40 PM
emorehs's Avatar
check this one out. ( https://g35driver.com/forums/g35-sed...ise-video.html) the clutch assembly goes bad and it actually girnd to each other.
Old Apr 11, 2013 | 09:13 PM
My sound isn't at such a high frequency and the noise doesn't sound like metal grinding like in the compressor issue.
But thanks.
Old Apr 15, 2013 | 08:55 PM
clyth83's Avatar
Experiencing the same noise
Hey Jason, I'm experiencing the same noise on my 08 G35X. I have approx 50k miles. I was thinking about taking it to the dealer, but I don't feel like paying the diagnostic fee either. Let me know if you make any progress.. Thx for posting.
Old Apr 15, 2013 | 08:57 PM
Interesting...i haven't decided what to do...if i go to the dealer i'll let you know, and you do that same
Old Apr 15, 2013 | 10:02 PM
vqsmile's Avatar
I just listened again, and after considering something related in another thread, I'm now also wondering if it could be a solenoid associated with the variable valve timing.
Old Apr 16, 2013 | 08:54 AM
I would think a VVT solenoid would be a much higher frequency
