on screen clock
Old Apr 16, 2013 | 07:46 PM
lansur's Avatar
on screen clock
I live in BC and am on Pacific time. The only way I can get proper clock reading (daylight savings time is ok) is to set my clock to Mountain Time (an hour later). Anyone know why this is or how I can change it? Thanks.
Old Apr 16, 2013 | 09:08 PM
Timbits93's Avatar
Well if it's an hour off, than wouldn't fixing the daylight savings time setting (even if you say it's okay) bring it back inline?
Old Apr 16, 2013 | 11:17 PM
vqsmile's Avatar
I'm assuming this is on the NAV screen and NOT the actual clock, right? Did you RTFM to see if all the settings are correct? If it's just off an hour it sounds too suspiciously like the DST setting, or something equally simple, is off.
btw, if it is the actual clock you are referring to then you really need to RTFM; the clock is set seperately by buttons immediately underneath it.
Old Apr 16, 2013 | 11:54 PM
lansur's Avatar
onscreen clock
Thanks. You assume correctly. It is the onscreen navi clock, not the analog clock. And (why I referred to daylight savings) the problem is independent of daylight savings mode. I have daylight savings on as I have for the past 4 years, but this year is the first that I have had to change my time zone - from Pacific to Mountain - so that the clock reads correctly. This is not a big problem but a problem nonetheless, which could be indicative of other Navi problems. Perhaps a Navi update - which I am loathe to pay for - would solve the problem???
Old Apr 17, 2013 | 12:00 AM
lansur's Avatar
(for vqsmile) I always RTFM!! And I thought I made it clear that the DST was set. Did you RMFP?
Old Apr 17, 2013 | 03:04 AM
vqsmile's Avatar
Sorry, then you are apparently one of the rare few who do. I did read it, but it was somewhat vague regarding the reference to a "clock reading", rather than a time display. Given that, and the overwhelming odds toward the simple being the norm here, I do hope you can understand my apparent haste in response. That said, my G doesn't have NAV, and it's been some time since I set the time in the one that does which I have access to. I think I'll take a look again and refresh what's involved. In the mean time, what is the location that shows up for your G ? I mean, does it (correctly) know where it is? or does it think you are in Colorado or something?
g.spot
May 9, 2016 10:54 PM
Chauzilla
Sep 27, 2015 04:34 PM
G2B35AGN
Sep 25, 2015 10:49 PM
