loud pitch sound from engine bay
Old May 10, 2013 | 11:59 PM
RJ01's Avatar
I recently installed Takeda Dual intakes and im hearing a loud pitch sound in the engine bay when the car is idling, anyone know what might be causing this ?
Old May 11, 2013 | 01:09 AM
vqsmile's Avatar
Inhalation
Old May 11, 2013 | 04:27 PM
RJ01's Avatar
Originally Posted by vqsmile
Inhalation
Could be, going to see how it goes the next few days and hopefully it goes away on its own!
Old May 11, 2013 | 06:30 PM
vqsmile's Avatar
If it is that, it's NOT going to go away.
Old May 11, 2013 | 06:51 PM
kool_yaar's Avatar
^ whs if what youre hearing a constant loud pitched sound of the intake taking in air after installing SRI then you should know that its common with most SRI with open front filter design
Old May 12, 2013 | 12:08 AM
RJ01's Avatar
Okay thanks ! I didn't hear it at all today so hopefully it stays that way
Old May 12, 2013 | 12:31 AM
vqsmile's Avatar
ok, so if it went away, then you need to describe the sound a bit better, because an intake sound won't change like that, so it most likely is something else. Is your serpentine belt slipping, AC clutch acting up, or one of the various pulley bearings starting to make noise?
Old May 12, 2013 | 12:48 AM
RJ01's Avatar
I will check it out tomorrow and get back to you tomorrow as well
Old May 12, 2013 | 05:57 PM
RJ01's Avatar
There is no loud pitch sound anymore.
Old May 13, 2013 | 01:40 AM
xilio's Avatar
Just a heads up, i got mine at about 100k on my sedan, *the sound that is* I had the serpentine belt and tensioner done and it went away. FYI at the time, my mechanic had told me that the belt had stretched alot and was on it's last legs, even though it looked fine. Its about 300$ for the service
Old May 13, 2013 | 11:27 AM
RJ01's Avatar
Thanks for the heads up, i'll definitely have it checked out!
pigpen infiniti
Aug 16, 2015 09:07 PM
Wayne9011
Jul 27, 2015 11:25 AM
