How to keep the car running cool in hot days
Old May 29, 2013 | 06:00 PM
stockae92's Avatar
I think this summer will be HOT in socal. I am wondering if there's anything (cheap) that I can do to keep the car running cool?
Any better coolant? (is there such things?)
Does synthetic oil helps?
Those battery and brake/clutch fluid covers, should I keep this in?
Take the engine cover out?
Just throwing idea out.
Old May 29, 2013 | 06:20 PM
vqsmile's Avatar
Since you're in SoCal, there's really no need for your car to run a 50/50 coolant mix. You could run a "leaner" 65% water / 35% antifreeze mix and have better cooling capacity for it. Beyond that, there's 'Water Wetter' products which are supposed to be even better still.
All that being said, there really no reason you should need to do anything. As long as your cooling system is performing to factory specs, it should be more than adequate to handle a measly little SoCal summer.
Old Jun 8, 2013 | 03:26 AM
princealyy's Avatar
I dont know why you would need to do anything to the car, I drove my car hard in the Texas Summer ... and I never had an issue, car has about 90,000 miles on it now ..
Old Jun 8, 2013 | 12:45 PM
Jairen's Avatar
Stay away from Water Wetter. It gunks up the cooling system.
Old Jun 8, 2013 | 01:01 PM
cvipgo's Avatar
G35 can handle So.Cali heat and more- i have 03 G35 with 131K miles, never touched anything to run it cooler, AC still runs like new. Don't need any thing done except maintained the car per the book.
Old Jun 10, 2013 | 07:41 AM
Mustang5L5's Avatar
Old Jun 10, 2013 | 02:24 PM
totopo's Avatar
if you are having problems, you can clean up your water radiator and remove all the debris built up over the years and straighten the fins
Old Jun 10, 2013 | 03:40 PM
dofu's Avatar
20 Year Member
Like everyone else said, your G will be fine in the SoCal summer. If you have an aftermarket intake, heat soak might affect performance a bit.
champppy
Mar 31, 2020 12:25 PM
mike730
Jan 12, 2018 04:25 PM
yassy
Aug 3, 2015 12:24 AM
ClwMike
Jul 23, 2015 12:55 PM
joel extreme
SOCAL Meetings & Events
Jul 23, 2015 04:13 AM
