Short Crank / Hard to start issue
Old Jun 5, 2013 | 01:49 PM
RedStil's Avatar
Hi guys I have a little issue with my car starting up. Sometimes, mostly when its cold, the car acts up and only cranks 1-2 times and stops (i can even feel the engine moving. Do I have a broken engine mount ) Some times more crank or only 1 crank then it stop or does a hard start. But it never does that when hot.
Tho,I have a check engine lights up cause my EVAP system have a gross leak.. (Returns gaz emissions to filter it)
So is it cause of the pressure loss? And I have to change my battery soon. Maybe the crank voltage isnt high enough?
Other then that, the car runs like a charm.
Thanks
JP
Old Jun 5, 2013 | 02:52 PM
ttv36's Avatar
When I had this issue in my FX it was because the battery was bad and cold weather amplified the issue.
Old Jun 5, 2013 | 11:09 PM
kool_yaar's Avatar
^ whs, have your battery tested at a local auto store for free and they can confirm if the battery needs replacing
chinee
Jun 10, 2024 07:48 PM
Hasanbaloch
Feb 29, 2024 08:45 PM
andyg35c1
Aug 29, 2015 03:37 PM
newg37
Jul 26, 2015 09:32 AM
itschuckster
Jul 25, 2015 08:07 AM
