AC quit on me today
Old Jun 13, 2013 | 05:42 PM
treacherous's Avatar
20 Year Member
G35x
AC quit on me today
I was full throttle merging onto freeway when all of sudden this loud whistling sound started to occur. It lasted for about 30 seconds and then went away. I was thinking great... I wonder what that was since that can manifest itself as a lot of things. Well on drive home I turned AC on and noticed no cold air. I must have blew some seal in the system I guess.
Looks like my Elite warranty will probably pay for itself after this one. I am taking in for a small leak on my transfer case but also for the AWD TSB for vibrations in turns. I think they replace the electric coupling in transfer case that is like $1K. I wonder with leak if they won't just replace the entire transfer case?
I still love her though!!
Old Jun 13, 2013 | 09:10 PM
muyrec's Avatar
nah it aint that. i remember reading the manual that those white rings are supposed to get loose after you connect the ac tubings. theres more of those as well. behind the engine theres 2 more. Does the compressor plate face engage when you turn it on?
Old Jun 14, 2013 | 08:47 AM
aquabat0587's Avatar
Do you happen to have a stillen gen 3 intake? I just had my ac go out a couple weeks ago and it was due to the intake pipe rubbing a hole in the metal ac line going to the condenser/radiator. I had to buy a new radiator...
Old Jun 14, 2013 | 07:42 PM
SergeantRed's Avatar
Before you do have you messed around in the steering column area recently? I did and managed to disconnect the sensor and hose. Mine stopped working too and I was pissed off. Check that before you drop money on a diagnoses....
Old Jun 15, 2013 | 09:37 PM
GL let us know
Old Jun 17, 2013 | 03:21 AM
vqsmile's Avatar
^^ lol . . . I think you might be on to something there.
Old Jun 17, 2013 | 09:19 AM
miltoda's Avatar
what part is this? Just curious. Is that the AC compressor clutch plate?
Old Jun 17, 2013 | 05:06 PM
Triton3.5's Avatar
came apart..... lol
Old Jun 17, 2013 | 06:02 PM
GR6RR's Avatar
mine came apart too. I found a used clutch on ebay, installed it, found a screw I had left over from my cbr, and bam! back to working again.
but you have warranty. let them have at it!
Old Jun 17, 2013 | 06:40 PM
vqsmile's Avatar
Originally Posted by treacherous
Yeah... compressor clutch disk.
I was able to get the G in for service today.
Under warranty at around $1800 for repair.
Work order states:
"REPLACE A/C COMPRESSOR ASSY/EVACULATE AND RECHARGE TO CORRECT. (FOUND A/C COMPRESSOR CLUTCH DISK CAME APART.)"
And that little repair paid for your extended warranty all by itself.
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
KallDay86
Jan 8, 2016 12:42 AM
Visionnn
Oct 3, 2015 05:16 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
