Rack and pinion???REBUILD???
Old Oct 9, 2013 | 10:00 PM
TONYG35S's Avatar
Is it possible to re build a rack and pinion with a seal kit , the problem im running into is that my rack and pinion is leaking from both sides when i turn my steering wheel left if leaks from the right when i turn my steering wheel to the right it leaks from the left Im assuming it is the rack and pinion cause the piston moves in the rack ad pinion it pushes fluid to the opposite side... i have exprenece re-building shocks, brakes, brake levers and ect things that do with seals c-clips and o-rings ...... has anyone re build a rack and pinion and any success????
if you have and ideas anything that would help let me know
Thnksss!!
Old Oct 10, 2013 | 07:52 PM
vqsmile's Avatar
Thnksss!!
I doubt Infiniti will sell you the internal rack rebuild parts, as they most likely only deal with a complete assembly. You might try a good aftermarket auto parts source for them, or you could try checking with a local hydraulic shop. They rebuild all kinds of odd-ball stuff all the time, so they may have (or know where to get) the particular seals, clips, etc The only trouble is, they will most likely not know until it's opened up and they see what it needs. Have you tried/considered sourcing a used one from an auto salvage yard?
Old Oct 10, 2013 | 09:43 PM
TONYG35S's Avatar
i found a seal kit on ebay for the rack and pinion and i work as a bike mech so i rebuild shocks and hydo.brake levers all the time c/clips . o rings so ima take a shot at it the kits only 20 bucks let see how it goes
Old Oct 10, 2013 | 11:36 PM
vqsmile's Avatar
Sounds good. Maybe you could snap a few pics as you go and post a little DIY for anyone that may follow in your footsteps.
Old Oct 12, 2013 | 12:12 AM
Mike45's Avatar
If it's not to much work can you take a few pictures, I have some rack and pinion issues too and wouldn't mind some extra info.
Old Oct 12, 2013 | 11:46 AM
henry206's Avatar
same here, my right side looks like it's been leaking as well. Do you guys know how difficult it is to fix? Tried looking up alldata and it didn't show up.
seagrasser
May 3, 2022 09:43 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Tmatheso
Dec 13, 2015 03:24 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
