Tpms?!!??
.02
it was a slow leak then I left the car in the garage for a week and it went completely flat so I didn't drive on it... after plugging it I've driven over 50 miles but its still on...I can try to overinflate I suppose until it goes off.. the tire is holding air fine now the light is just annoying. thank you for all of the help everyone
Posted from G35driver.com App for Android
How about the other tires? since it was parked I would check the pressure in all 4 tires.
Did you resolve this? I read online, that if you inflate it to 40psi, drive around for a while..the warning will go off. and then , you could deflate back to 33. It apparently worked for many people. Btw, I got the same issue . going to try it next and then will take it to the dealer.
Mine comes on after driving for about 15 miles and stays on till I shut the car off. Once I restart it's off for another 15 or so miles pressure is 36 all the way around. Any ideas?
Try inflating all your tires to 38psi (not when cold, drive around for a bit until you reach a station so they get hotter.)
Mine turns off after about a minute when I do so. I know one of my tires has a slow leak, and it isn't any puncture or anything, since I changed out the whole tire and it is still leaking very slowly. I suppose one of my valve stems is leaking.
I don't know of any quality tire store that will "Plug" a radial tire, and I wouldn't want one on my ride! I won't go into the whys, but they're not safe at hwy speed! You could try deflating and inflating that tire but make sure it stays at a constant 35 psi. TPS should go off in a few blocks not miles...Gary
OK just left Discount Tire...they reset the TMPS sensor and presto problem solved...free of charge. I appreciate all of the suggestions and help from the forum.
