Rattle noise in drive and reverse
Old Oct 26, 2013 | 07:04 PM
kb24888's Avatar
My 2007 AT G35x makes this rattle noise from underneath the car when it's only in drive and brake is applied or reverse and brake applied. But nothing when in park or neutral. I can only hear it if I'm stopped at red light beside another car or stopped by a wall. There is no noise from the engine bay even when I left the car in drive and applied the safety brake and opened the hood. The noise is loudest when first starting the car when cold and gets quieter as it's driven and warmed up to the point where I have to crawl on my knees and have me head underneath the car to hear it. What could this be?
Old Oct 26, 2013 | 07:48 PM
mathnerd88's Avatar
Check your catalytic converter heatshields. They're probably rusted and rattling right now.
Old Oct 27, 2013 | 01:26 PM
kb24888's Avatar
Could it be anything else? Cause I've already ripped most of it off before but there is certain parts I've left.
Old Oct 27, 2013 | 01:27 PM
mathnerd88's Avatar
You have to take all of it off. The top portion may be loose too.
Old Oct 27, 2013 | 02:12 PM
gary c's Avatar
Removing the cat covers piece by piece isn't the way to fix this issue! For a small fee any muffler shop will weld the converter shields for you. Doing it right will fix the problem and it won't happen again!
Gary
Old Oct 27, 2013 | 04:12 PM
kb24888's Avatar
I got under there and let the car run when I heard the rattle I held a screw driver to various pparts of the catalytic converter and it stopped rattling when I held it this bracket or something that it's bolted to, towards the front of the car. Could it be a loose bolt or something?
Old Oct 28, 2013 | 02:37 PM
kb24888's Avatar
Any ideas?
Old Jan 7, 2014 | 09:29 AM
dcp883's Avatar
What did you find out? I have the same noise, but no rust on the heat shields. Maybe something inside like the actual material in the housing breaking up and rattling? Also i noticed when starting the car that my exhaust is fumes are stronger than usual.
Old Feb 2, 2014 | 06:26 PM
dcp883's Avatar
I removed my heat shields and still had the rattle sound. I found out one of the cat cores is broken and is tumbling around inside.
Old Feb 2, 2014 | 06:29 PM
kb24888's Avatar
Mine was the brace or whatever that is welded to the cats was broken at the weld point and was just re-welded.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Calvin
Southern California
12
Oct 15, 2015 04:21 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
rping
Jul 26, 2015 09:53 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
