Alignment!??
Old Nov 14, 2013 | 07:57 AM
pbabajan's Avatar
Alignment!??
im pretty sure this is a dumb question since i cant seem to find a thread about it at all, but, do i need to buy a camber kit to align my wheels?
i just got new tires and the shop said my camber is really negative and that they cant align cause no camber adjustment!?
did infinti think this car would never need aligning?
Old Nov 14, 2013 | 09:00 AM
mishmosh's Avatar
Stock suspension? There should be no reason why you can't get it into proper range if so. Front has no camber adjustment but rear does.
Old Nov 14, 2013 | 01:06 PM
stockae92's Avatar
Any accident before? Anything bent or lose or doesn't look right?
Old Nov 14, 2013 | 02:11 PM
E-Ticket Ride's Avatar
Find a new shop
Old Nov 14, 2013 | 03:57 PM
botlfed98's Avatar
stock springs?
Old Nov 16, 2013 | 09:39 AM
pbabajan's Avatar
yeah stock suspension! what are my options to get the front aligned?
Old Nov 16, 2013 | 09:53 AM
gary c's Avatar
There are no dumb questions! If your car hasn't been in an accident a quality alignment shop should be able to align your suspension to factory specs so you get decent tire wear. How many miles do you put on your front tires before they need replacing? Find an independent brake/alignment shop in your area, have them check your suspension and alignment. Stores like Goodyear or Firestone don't know enough to solve your issues.
Gary
Old Nov 16, 2013 | 10:28 AM
pbabajan's Avatar
nope no accident! not too sure on how many miles since this is the first time i had bought tires since owning!
thanks for all the responses! love this forum!
gonna check another alignment spot out! thank u guys, i almost went to the stealership!
Old Nov 17, 2013 | 12:33 PM
mishmosh's Avatar
Let me tell you. I'd rather go to the dealership than some two bit shop or tire place to get my alignment.
Old Nov 18, 2013 | 07:01 PM
mathnerd88's Avatar
Go to another shop, but if they also say the same thing, I suspect your car has been in an accident before, especially if your camber is "really negative" like what the shop says.
It doesn't have to be a major repair accident. It could be when you accidentally ran over a curb (quite common.) I see so many cars running over curbs when they make too narrow of a turn at a traffic light.
Old Nov 18, 2013 | 07:49 PM
gary c's Avatar
Ok you did.......you're seriously better off going to a shop that's in business to do alignment! Most Infiniti stealerships send there alignment work out to those shops and double your cost...aka stealerships!
Gary
Old Nov 18, 2013 | 08:13 PM
mishmosh's Avatar
Gary
Not disagreeing with you there. I send both my cars to a specialty alignment shop. If I need new tires balanced, I will have Tirerack ship them there also.
But most dealerships have their own alignment rack or share among several franchise dealerships next to each other. Dealerships will usually have some of the best tire balancing equipment also, ie. Hunter GSP9700.
Old Nov 19, 2013 | 02:15 AM
pbabajan's Avatar
hmmm, dont remember jumping off a curb but might be possible since my brother and friends drive my car every once and again! But the shop did tell me im negative 1 or something on both front and back! gonna go to a different shop to see if i can at least get the back!
any idea what my options are for the fronts since they cant be adjusted??
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
MThawkins86
Oct 24, 2015 02:07 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
migurus
Sep 5, 2015 09:39 PM
