Cause for the dreaded P0011/P0021 codes that everyone is curious about
Old Sep 11, 2016 | 03:30 AM
  #331
Dephect's Avatar
Took them about 14 hours, I think the water pump added another hour of labor.
Old Sep 23, 2016 | 10:34 AM
  #332
willdogs's Avatar
Ugh - just got the P0021 code and the car sounded like a tractor engine. I restarted the car a few times and it sounds good now, but then it happened again shortly after.
Going to a local mechanic to read the oil pressure this weekend, hope its not low, but from everything i'm reading here, sure sounds like it will be.
93,200 on the clock and never had a mechanical issue before this.
Old Sep 23, 2016 | 05:42 PM
  #333
willdogs's Avatar
UPDATE:
Mechanic connected a pressure gauge and the Oil Pressure is 35psi at Idle!!! I'm stoked!
So I guess I just maybe need to perform the tune up i've been putting off and hope for the best? Still on original plugs with my mileage, thinking maybe thats the issue?
Any other ideas?
Also could bad gas cause this? My wife filled up last week at a shady gas station. How about using regular instead of Premium? She's not sure what type she used
Old Sep 23, 2016 | 08:59 PM
  #334
vqsmile's Avatar
Originally Posted by willdogs
UPDATE:
Any other ideas?
Will, to be honest, the fact that they read 35 psi at idle makes me suspect they didn't do the measurement correctly, because that is too high of a reading to be getting at idle. I'm not saying that oil pressure is your issue, but there is just no way you should be getting 35 psi at 650RPM. It would appear they flubbed making measurement per factory specs.
Old Sep 23, 2016 | 09:10 PM
  #335
Da_skyliner's Avatar
I was thinking the same...
Old Sep 23, 2016 | 09:36 PM
  #336
blnewt's Avatar
Maybe he's idling at 2k
Old Sep 23, 2016 | 10:51 PM
  #337
willdogs's Avatar
Oh crap really? I saw the gauge for myself...
Thats what I get for going to a local shop, maybe his gauge was malfunctioning.
I'll just bite the bullet and take it to the dealer for diagnosis, I just don't trust dealers to tell me the truth, my mechanic lets me get all up inside the work area to see things for myself
Old Sep 23, 2016 | 10:53 PM
  #338
Was the car cold or at normal operating temp?
Old Sep 23, 2016 | 11:06 PM
  #339
willdogs's Avatar
Normal Operating Temp
I drove around for about an hour, dropped the wife at home, went the the garage and they put my car on the lift right away.
Pressure was checked about 20 min after the car was put on the lift and the car was turned off.
Old Sep 23, 2016 | 11:07 PM
  #340
willdogs's Avatar
Should I even bother giving it a tune up this weekend? I know for sure three things need to be done...plugs, clean my K&N air filters as it's been more than a year and they are black and clean the TB - i've never cleaned the TB plenums.
Would any of the above three items throw this code?
Old Sep 23, 2016 | 11:10 PM
  #341
To my knowledge no but I'm NO EXPERT just a follow enthusiast. I also thought the car needed to be running to check oil pressure.
Old Sep 23, 2016 | 11:15 PM
  #342
willdogs's Avatar
Sorry yes the car engine was running at idle when the pressure gauge was checked. Forgot to mention that part.
  • Arrived
  • Car on lift
  • Car turned off
  • Pressure gauge installed
  • 20 minutes later car turned back on
  • Pressure around 32psi at idle
Old Sep 24, 2016 | 12:53 AM
  #343
vqsmile's Avatar
  • Arrived
  • Car on lift
  • Car turned off
What were the rpms at idle? Did they monitor that? If it was idling at more than 650, then the readings would go up significantly with the increase in rpms. Even an extra 50-100 rpms can raise it by 5-10 psi.
Old Sep 24, 2016 | 12:57 AM
  #344
willdogs's Avatar
crap they didn't look at the RPM, I just started it and we all rejoiced that it was above the 14 PSI previously mentioned.
Guess maybe it's time for a re-test
Old Sep 24, 2016 | 01:05 AM
  #345
vqsmile's Avatar
Yeah, if it ever comes to a dealer for a warranty claim for low oil pressure, in addition to the PSI, they will closely observe the rpms, oil temp, oil specs, filter type, and any aftermarket products that may affect it. When I took my car in, they made me change the oil, the oil filter, and remove the oil pressure gauge I had hooked up before they would consider any PSI reading to be accurate (for warranty purposes).
You have already rated this thread Rating: Thread Rating: 4 votes, 4.00 average.
