Cause for the dreaded P0011/P0021 codes that everyone is curious about
#31
![Icon43](https://g35driver.com/forums/images/smilies/icon43.gif)
FYI, they have IPB's and part numbers here: http://infiniti.sewellparts.com/part...edan-2008.html
#32
#34
#35
On the V35 models like ours the P0011/P0021 codes are normally caused from low oil levels. If your oil level is ok then the intake valve timing solenoids may be bad as they work off of oil pressure. These are the 2 solenoids at the front of each valve cover and I think they have a green connector on passenger side and a blue connector on the driver side. We don't have the paper gaskets that blow out like the V36 models do. More than likely if you let your car sit for about 20 minutes and check the oil it is probably low. If it is low, just top it off and reset the ses light and you should be fine. Hope this helps bro...
Any ideas? Also, how do I delete posts? I accidentally didn't quote this the first time...
#36
So recently I borrowed an OBD2 reader from a friend and cleared the codes, topped up the oil. I drove for about 60 miles on the highway and city without the code, stopped to get gas, and it came back shortly after...
#37
#40
#42
#43
Hi everyone, quick question. I have an 08 G35X that is putting out codes for P0011 and P0021. My car has 108K miles on it, so I really don't want to spend $2K or $3K to have them rip apart the cam and fix this gasket problem. Can someone tell me if I keep driving my car with this problem, will I be seriously damaging my engine? I don't understand engines enough to know if this gasket did blow out, will it seriously harm my engine to keep driving it? The car starts, and runs great with no issues other than the check engine light on! Thank you..
#44
Well, I drove my car for about 5 months while I was trying to figure it out and fix it myself. Then I had no choice but to give in and take it to the dealer because I was up for state inspections. Regardless, the only issue you will run into is not passing inspection I would assume. My car "seemed" to be running great but after getting it back and driving it, it was completely different and felt more like a restored engine. I would maybe check with a independent repair shop and see if they can do it for less than the $1500 that I paid to the dealership. Hope you find a resolution!
#45
