Weird squeaking/rubbing when I turn right
Old Jan 31, 2014 | 09:49 AM
dcp883's Avatar
So I'm getting this weird rubbing-squeaking like sound coming from the back of the car when I turn to the right. The sound started a few weeks ago when I was taking an off ramp to the right. Today I noticed it made the same sound in a parking lot at a slow speed.
Also the rear seems a bit loose while cornering. Might be the rear bushings, but I'm not sure if that could contribute to the squeaking rubbing sound.
By the way I have a 2008 G35Xs with 111,000 miles.
Any thoughts?
Dave
Old Jan 31, 2014 | 09:51 AM
Urbanengineer's Avatar
Pop it up on a lift and have a look. You more then likely just have a loose bolt.
Old Jan 31, 2014 | 10:04 AM
dcp883's Avatar
I'm getting it up on a lift this weekend. Hopefully something simple to fix...
Old Feb 2, 2014 | 06:11 PM
dcp883's Avatar
Found out my rear passenger side inside brake pad somehow got jammed and wore away down to the metal. One of the long pins that hold the calipers together became rusted and was stuck.
Pretty easy fix and problem solved.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Rinaldi
Dec 2, 2015 05:29 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
