Lots of shaking
Old Jan 31, 2014 | 04:40 PM
kb24888's Avatar
Lots of shaking
My 2007 X with around 115000 KM started to shake when idle a couple of days ago. As soon as I start it up it shakes or when I'm at a red light. I can feel it through the drivers seat. My RPMs are stable and the same as usual, nothing weird happening there. Yesterday it was shaking so much when I first started it up in the morning that I heard something rattling from underneath the car.
A couple days before all this started I was experience really bad fuel economy, I don't know if that is related to this. What could be causing this?
Old Jan 31, 2014 | 06:52 PM
mishmosh's Avatar
Is maintenance up to date? spark plugs etc.?
Old Jan 31, 2014 | 07:30 PM
herrschaft's Avatar
I take it there are no codes? Seems too new to be engine mounts but I would check there first.
Old Feb 2, 2014 | 06:33 PM
kb24888's Avatar
There are no codes. The maintenance is upto date except I need to change the AT oil. But can that cause shaking? The plugs I thought were at 115K miles?
Old Feb 2, 2014 | 07:43 PM
kb24888's Avatar
Originally Posted by treacherous
ITB11-018a ?
2007 – 2008 G35, 2008 EX35 AND 2009 – 2010 FX35;
ENGINE HESITATION OR STOPS RUNNING AT IDLE OR VERY LOW SPEEDS
APPLIED VEHICLES: 2007 – 2008 G35 Sedan (V36) 2007 G35 Coupe (CV35)
2008 EX35 (J50)
2009 – 2010 FX35 (S51)
IF YOU CONFIRM
The customer reports any of the following:
• Engine hesitation at idle or very low speeds,
and/or
• Engine speed drops lower than expected when decelerating or coming to a stop,
and/or
• Engine stops running at idle or very low vehicle speeds (parking lot maneuvers), but can be restarted.
NOTE: this incident may occur immediately after an oil change. ACTIONS
1. Refer to Step 2 in the Service Procedure to confirm this bulletin applies to the vehicle you are working on.
2. If this bulletin applies, reprogram the ECM.
No the engine never stops, only shaking or vibration is felt.
Old Feb 2, 2014 | 07:48 PM
coffeysm's Avatar
Is it a constant shake or comes and goes? My car would sporadically shake at idle when I had a vacuum leak. Do you have access to something that can show you real-time data?
Old Feb 2, 2014 | 07:54 PM
kb24888's Avatar
No I don't. What type of vacuum leak? Could you smell anything?
Old Feb 2, 2014 | 09:44 PM
coffeysm's Avatar
Well, in my case there was a leak between my brake master cylinder and brake booster. This caused additional air to be sucked into my engine messing the fuel trims up. You don't really smell anything, but if your car runs with no loss of power it could be a vacuum leak.
You'd want to check your connections between the plenum, intake tube, and vacuum lines.
Old Feb 3, 2014 | 11:06 PM
vqsmile's Avatar
Could it just be a fill of bad gas? It happens.
Old Feb 6, 2014 | 01:05 PM
kb24888's Avatar
What if there is power loss, I have noticed that now
Old Feb 6, 2014 | 06:36 PM
Anton_Chigurh's Avatar
motor mounts
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
prinny
Nov 22, 2015 11:07 PM
