Rattle/Squeak Center of the Dash below the vents
Old Mar 4, 2014 | 05:01 PM
chrisg37's Avatar
Hi I have Rattle/Squek Center of the Dash below the vents which has worsened with the winter cold. I have tried removing the cowl and padding it like the sticky which I initially thought was the issue but no dice. I also tried placing a towel and padding between the dash with no luck.
It can be described as a loud squeak in the top of the dash just under the defroster vents.
Has anyone else had this issue/fixes?
Car is out of warranty so I need to fix it myself.
Old Mar 5, 2014 | 02:46 PM
stockae92's Avatar
I don't know if that's related, but there was a TSB for noise from dash and it got something to do with cleaning the ducts I think.
I got the similar issue but it comes and goes. The dealer simply said they can't reproduces the problem and they never did anything about it
Old Sep 14, 2015 | 11:00 AM
skippyG's Avatar
I have a "chirp" that sounds like crickets from the same general area - doesn't do it all the time... Drives me nuts!
Old Sep 14, 2015 | 12:33 PM
willdogs's Avatar
LOL same here. I can't find it! Its driving me insane. Only makes noise when I hit bumps
Old Sep 19, 2015 | 01:27 PM
skippyG's Avatar
Mine stops when I hit bumps!
Old Oct 2, 2015 | 05:25 PM
skippyG's Avatar
Found & cured my squeak - found an old thread that said it was caused by a loose battery. It said that you hear it squeak inside because it's near the fresh air intake.... Tightened it down, problem sloved!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
w4kj4k
Oct 2, 2015 07:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
master111
Sep 25, 2015 08:32 PM
