2008 G35x Sedan Brakes - DIY Exist?
Old May 1, 2014 | 09:35 PM
JustinMKN1's Avatar
2008 G35x Sedan Brakes - DIY & Parts
Hey Folks, I'm going through my 90k maintenance, brakes, fluids, etc. I'm leveraging quite a few DIY Threads at various places. I did my front brakes and rotors tonight and I didn't see a thread for 2008 Sedan (Stock brakes). Found a good (Similar) write up on another forum I wanted to share.
http://www.nicoclub.com/archives/g35...brake-job.html
Def saved me $300 for around 1.5 hr job.
Ordered several parts off Amazon as well (Not sure on best price)
Front:
Centric Parts 120.42080 Premium Brake Rotor with E-Coating - (Front Rotors, order 2) - $59 ea
StopTech 309.08880 Street Performance Front Brake Pad - (Front Brakes, order 1) - $62 for the set (of 4 pads)
Rear
Centric Parts 120.42088 Premium Brake Rotor with E-Coating (Rear Rotor, order 2) - $44 ea
StopTech 309.09050 Street Performance Rear Brake Pad (Rear Brakes, Order 1) - $47
Hope this helps!
Old May 4, 2014 | 10:15 AM
RemmyZero's Avatar
Always a great DIY to have handy. Thanks!
Old May 5, 2014 | 07:32 AM
JustinMKN1's Avatar
Originally Posted by treacherous
Fronts are relatively straightforward and easy... the rears I have had to compress the suspension some with another jack to get the clearance needed to remove one of the caliper bolts. On my car there is no way for this one bolt to come out with car just jacked up from the rear diff.
EDIT: I see that in the write up. "4> Remove the 14mm bolts on the back of the caliper that that hold it to the mounting plate.The rear calipers bottom bolt will not clear the trailing link until you remove the caliper mounting plate."
I'm going to be trying to rear brakes this upcoming weekend, hopefully they werent to bad after you got that mounting plate off? Thanks for the heads up though!
Anyone know if I should use Anti Seize on the actual bolts holding the caliper on? I only saw it mentioned for the rotor. (ex 22mm & 14 mm).
I'm going to try to bleed all the brakes and flush the system as well, got a 1 man bleeder bottle to help out.
kinetek
Aug 3, 2015 04:25 PM
rping
Jul 26, 2015 09:53 PM
richmc
Jul 26, 2015 08:13 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
