AC Compressor Noise Thread
Old May 4, 2014 | 12:53 AM
Mike45's Avatar
A while back there was a thread about the noise from the ac compressor when the ac was on and someone had posted a fix for it including a picture(s) and a quick DIY on how he fixed it using from what i remember was a washer.
I have been searching for a while now and can't find the thread. Anyone have it bookmarked? or remember the title?
Thanks
Old May 6, 2014 | 02:38 AM
TEX4S's Avatar
I would like to know this as well as mine is kinda noisy on an otherwise quiet car.
Old May 6, 2014 | 05:54 AM
Eric@TCGMiami's Avatar
Usually when this noise occurs it's either the clutch is wearing out
OR
Your cooling system is not working up to par causing the condenser to build up pressure. If you get off the highway almost immediately roll down your window and continue to hear the loud noise you could be in the route to buy a new a/c compressor soon.
But if you don't hear the compressor for a few moments then begin to hear it louder and louder; that means it's a tale-tale sign that your Radiator/Fans are suffering some type of loss and the a/c is just building up on pressure.
Old May 7, 2014 | 09:37 AM
vdoh8687's Avatar
Thanks
This page talks about the problem and needing a washer or spacer but I don't know if anyone actually sourced one: https://g35driver.com/forums/g35-sed...ise-video.html
Old May 11, 2014 | 11:40 PM
G force's Avatar
The source was posted but no solution update.
Old May 12, 2014 | 06:01 PM
Mike45's Avatar
Yah this is the thread thank you.
After reading through it and contacting the guy who did the fix it seems like he was fixing a different problem then me.
Old May 12, 2014 | 11:33 PM
infinitidude's Avatar
I have replaced a lot of ac compressors on V36 model sedans. They are becoming more and more of an issue here lately on some of the higher mileage cars.
Old May 13, 2014 | 09:42 PM
G force's Avatar
Wonder if it's something worth replacing preventive rather than waiting until it blows shrapnel into the coil and lines.
Old Sep 17, 2014 | 09:28 PM
tbear35's Avatar
Can the clutch be replaced as a separate item?
magnetism80
Feb 1, 2019 10:00 AM
3000vr4tt
Sep 7, 2015 12:48 AM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
TheBay
Sep 3, 2015 03:27 PM
