Vale cover leak fix?
Old May 24, 2014 | 01:06 AM
Victorg35s's Avatar
Well like every infiniti the valve cover is leaking i have found a complete gasket kit for it with the o rings the problem is that its for a 2007 infiniti g35
I have a 2008?
Any difference ? I dont know is i still have warranty on the car the link to the gasket:
http://www.partsgeek.com/catalog/2007/i ... asket.html
Old May 24, 2014 | 03:09 AM
Mike45's Avatar
That link does not work.
Yes a 07 sedan part will fit your 08 sedan
Edit: here is one for $15 http://www.carid.com/2008-infiniti-g...ZHPtN9hRrw_wcB
Old May 24, 2014 | 11:26 AM
Victorg35s's Avatar
I need the o rings the one that goes around the spark plug holes I got oil on the drive back one and everyone has said Ithat you need to buy the while valve covers
Old May 25, 2014 | 07:49 PM
G35S.6.0.4's Avatar
Yeah, unfortunately you're going to have to purchase new valve covers. The valve covers on our cars have the o rings embedded in the valve cover itself so its not replaceable. Im on the same boat as you right now, I'm going to order the parts online and have my dealer install it. Dealer asks $780 for parts when I can buy it online for $370 lool.
Old Dec 8, 2015 | 10:08 PM
Cbst09's Avatar
New owner here. I bought a 2008 G35 last week with 107,000 miles on it and did a bunch of DIY stuff on it including brake fluid flush, oil change, and ATF drain and fill and spark plugs. I bought Denso FXE22HR11 Iridium Long Life Spark Plugs for about $10 each after coupons and discounts at Advance Auto Parts. Now for the bad news, when I got to the plug on the passenger side closest to the firewall I noticed that the plug threads were wet with what looked like fresh oil, the tube was not filled, just a small pool at the bottom( about a teaspoon. From the searches I have done it sounds like the valve cover needs replacing. The car is running fine and not throwing any codes. What have your experiences been with this, do I have to replace the valve cover or can I just periodically go in and check that plug and mop up any oil that is in there? Thanks
Old Dec 9, 2015 | 07:12 PM
MaxumG35's Avatar
Your going to have to get new covers. I had oil leaking around the bottom gasket seal. Too bad they don't make/sell the rubber seals separately. I still have my original valve covers and I can sell them for cheap if you want. Then all you'd have to do is reuse or get a new gasket seals and save a ton of money.
murphd3rf
27
Oct 16, 2023 02:15 AM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
yassy
Aug 9, 2015 07:31 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
