G35s fog light sport bumper
Old Jun 27, 2014 | 02:06 AM
Victorg35s's Avatar
Has anyone tried to use the hella micro de???
I was just planning to put the L shape DRL led any advice?
Old Jun 27, 2014 | 09:04 AM
equifire's Avatar
I'd just say don't do the L shape LEDs like the Mercedes. I did a triangle pattern like the G37 led kit and it compliments the shape of the sport bumper really nicely.
Old Jun 27, 2014 | 10:09 AM
Victorg35s's Avatar
That looks pretty good 0-0 I may consider that I was going to get the l shape but it looked cheap I did look at those but idk what form I should put them how did you wire them ? Did you use a risistor ? I was thinking about wiring them to my drl that's where I have my halo rings wired to
Old Jun 27, 2014 | 10:16 AM
Victorg35s's Avatar
Also what are the specs on the eagle eye ? 3w 9w 10w?
Old Jul 1, 2014 | 06:22 PM
ascott905's Avatar
Originally Posted by Victorg35s
Has anyone tried to use the hella micro de??? I was just planning to put the L shape DRL led any advice?
what did you do to your headlights? Did you just paint the inside of them black? They look amazing
Old Jul 1, 2014 | 06:24 PM
e_nigma's Avatar
That's a cool look. I'm sure it looks hot at night
Old Jul 2, 2014 | 01:10 AM
Victorg35s's Avatar
I did COB halo rings with 5 min epoxy ...... Dupli color hi temp paint from any auto zone pep boys etc......
1. Heated the headlight at 250 degrees 8-10 min make sure you remove the light harnesses and any plastic that is on it .
2. I opened them from the flat part of the head light and started to open it there is a DIY on it somewhere on this forum
2. Self etching primer....... Make sure you cover your lens apply 2-3 coats
3. Paint them with the hi temp duplicolor spray paint I'll post pics I didn't take many I should have .......
4. to seal it I use 3m window weld from pep boys or I Reilly's pep boys was 18$
And should be done
Old Jul 2, 2014 | 01:12 AM
Victorg35s's Avatar
It blinds me at night....... Can't take a good pic I'll try to use my Nikon I'll post pics
Old Jul 2, 2014 | 01:27 AM
Victorg35s's Avatar
Old Jul 2, 2014 | 01:48 AM
ascott905's Avatar
I did COB halo rings with 5 min epoxy ...... Dupli color hi temp paint from any auto zone pep boys etc...... 1. Heated the headlight at 250 degrees 8-10 min make sure you remove the light harnesses and any plastic that is on it . 2. I opened them from the flat part of the head light and started to open it there is a DIY on it somewhere on this forum 2. Self etching primer....... Make sure you cover your lens apply 2-3 coats 3. Paint them with the hi temp duplicolor spray paint I'll post pics I didn't take many I should have ....... 4. to seal it I use 3m window weld from pep boys or I Reilly's pep boys was 18$ And should be done
thanks man hopefully I'll have some time to do it then I'll post some pictures
Old Jul 2, 2014 | 08:20 AM
equifire's Avatar
No resistor just 3w LEDs and a relay. I posted the links in this thread.
https://g35driver.com/forums/g35-sed...-think-11.html
Old Jul 2, 2014 | 09:13 AM
Victorg35s's Avatar
[QUOTE="equifire;6918250"] No resistor just 3w LEDs and a relay. I posted the links in this thread. https://g35driver.com/forums/g35-sed...-think-11.html[/QUOTE
The relay is like the ones you would connect to fogs right?
Old Jul 2, 2014 | 10:20 AM
equifire's Avatar
Yup, same ones made for Led fogs.
Old Jul 3, 2014 | 04:50 PM
ascott905's Avatar
Hopefully I'll start this in the next week or so
Old Jul 3, 2014 | 04:52 PM
ascott905's Avatar
My headlights move as the steering wheel turns left or right. Do yours also and if so does that affect the halos attached to the projectors or are they fine?
