Window Switch Popped Off
Old Jul 29, 2014 | 12:48 PM
malicemethods's Avatar
I've had my 07 G35 Sedan since it was an infant. She has about 160K miles on it and still runs great. With the exception to the interior trim paint peeling and normal wear on the outside, I have no complaints.
Couple days ago the driver window switch popped off. I tried to push it back in but it looks like the plastic prongs that once held the switch in place have broken over constant use through the years. Right now I have it set in place to keep using it as a switch for the window. It is very very loose and can easily be taken off. Does anyone know where I can get a replacement window switch module, or just one window switch? Any other fix recommendations? Thanks for the help.
Old Jul 29, 2014 | 12:57 PM
Found the Left Window Switch part on infinitipartsusa part number: 25401-JK42E. Its $300. Ridiculous. Anyone know a cheaper fix?
Old Jul 29, 2014 | 05:50 PM
ernestTbass's Avatar
I can only find slightly less expensive ones on eBay - $280-290 so not much help there, but you might want to try taking the trim piece off to get a better look and see if there is some way to connect it back. I used an ice pick under the corner to pull mine up when I replaced it due to the common peeling problem. Good luck.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
