Engine Oil Leak? (w/ pictures)
Old Aug 25, 2014 | 01:29 AM
MikeJones916's Avatar
Hey everyone.
I was looking for some advice on what you think this issue is.
So the last time I changed the oil in my 2007 Journey I noticed there was some caked on oil on the splash guard on the bottom of the car.
I completely cleaned off the splash guard and as much as I could under the car, completed the oil change, and continued driving.
5,000 miles later I pulled off the splash guard to check on the status of the leak, the results are this:
(1) There is some oil on the splash guard, not nearly as much as before when I cleaned it but still noticeable.
(2) The engine bay underneath has liquid oil drips and some cake on.
(3) When I checked the oil level, I was maybe 1/8 of a quart low, but still in the normal range.
So I took some pictures which you can see below. What do you think it is?
Size:  122.1 KB Name:  20140820_192556_zps3da33f75.jpg
Size:  137.7 KB Name:  20140820_192612_zps2f8d8fe2.jpg
Size:  140.9 KB Name:  20140820_192617_zps01ad0734.jpg
Size:  143.6 KB Name:  20140820_192634_zps34ab8b67.jpg
Size:  152.9 KB Name:  20140820_192734_zpsef10db52.jpg
Old Aug 27, 2014 | 01:15 PM
Anyone have any thoughts on what this might be?
Is this a known issue with some seal or something that is easily replaced?
Any input is appreciated
Old Aug 27, 2014 | 01:45 PM
Deepdiver's Avatar
have you checked your valve cover gaskets?
Old Aug 27, 2014 | 02:54 PM
Texasscout's Avatar
Are you sure it's motor oil? Isn't that the AC compressor?
Old Aug 27, 2014 | 03:09 PM
willdogs's Avatar
Looks like it's coming from up top, the bottom looks clean. I would guess either Valve cover Gasket Leak or possibly oil from your A/C compressor
Old Aug 27, 2014 | 04:46 PM
tbear35's Avatar
May want to clean everything off and start checking it every few days if the valve cover gaskets look okay.
Old Aug 29, 2014 | 07:59 PM
emorehs's Avatar
As everybody said try to clean everything first then check it again for a couple of days... by then you will definitely encounter where the oil coming from.. take an eye on your timing cover and head gasket. IMO its coming from top then it leaked down... just my cent.
Old Aug 29, 2014 | 08:46 PM
Eric@TCGMiami's Avatar
Valve Cover Gaskets
Old Sep 1, 2014 | 12:18 AM
Thanks for the input everyone.
I too think it is coming from up top but it's hard to see anything from above.
To check the valve cover gaskets, do I just need to pull off the plastic engine cover?
Also, yes, it does look and smell like motor oil, but I'm curious, what else could it be if not that?
I haven't had to add any other types of fluids, just motor oil, but I am open to any ideas!
Thanks again everyone
_Michael
Old Sep 15, 2014 | 02:48 PM
So I took my car into Midas to see if they could isolate the oil leak.
They looked under the car and under the hood, removed the intake and their conclusion is that the timing cover is leaking.
With parts and labor he is estimating around $1,500 in repairs which includes about 6 hours of labor.
He was willing to do a UV dye test to attempt to isolate it further but was pretty confident that the timing cover is the culprit.
Does this sound legitimate? Has anyone had issues like this or completed the same type of repair?
Thanks again.
_Michael
Old Sep 15, 2014 | 06:01 PM
tbear35's Avatar
There is a post thread about p0071 codes (I think) that describes replacing the timing cover. That sounds like a typical price from what I remember.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
