UpRev Tuned
Old Oct 10, 2014 | 06:30 AM
Jeremy1607's Avatar
UpRev Tuned
Hi people,
I just got my car UpRev tuned by a workshop. I'm just wondering why are my numbers so low ? I have short ram intakes, HFC's, cat-back exhaust, new spark plugs, Splitfire SDIS coilpacks and Stillen grounding kit.
A friend who also has the exact same car as mine with just cold air intakes made 210WHP before and 260WHP after the tune.
Anyone have any ideas why ?
Thanks !
P.S Car is a 2007 Infiniti G35S Sedan (RWD VQ35HR)
Old Oct 10, 2014 | 07:11 AM
Shawno72's Avatar
Maybe a different dunk machine? Different machines can show different gains. Bye get your self a plenum spacer, you need it to open up your breathing.
Old Oct 10, 2014 | 08:18 AM
Jeremy1607's Avatar
I didn't know there's plenum spacers for the HR motor ? Lol
Old Oct 10, 2014 | 08:21 AM
Shawno72's Avatar
Lol oops. Duh. That's what I get for not reading closely. Sorry
Old Oct 10, 2014 | 08:24 AM
Jeremy1607's Avatar
Haha all good, the tuner told me having bigger wheels and semi-slick tires can also play a part on the dyno ? Is it true ?
Old Oct 10, 2014 | 08:26 AM
Shawno72's Avatar
Well if your not hooking up that can certainly happen.
Old Oct 10, 2014 | 08:28 AM
ScraggleRock's Avatar
Yes. Bigger wheels/tires make for a taller gear ratio. Its not gonna transfer power from the motor to the street the way you want it to.
Old Oct 10, 2014 | 08:50 PM
vqsmile's Avatar
Did your friend have his car measured on a Dyno Dynamics dyno also?
(HINT: They're not called the heartbreaker dyno for nothing)
Old Oct 10, 2014 | 11:07 PM
bat6wc's Avatar
My X put down 260awhp or so several years ago.
Regardless of your actual numbers, am I to believe you really gained more than 50whp with just your bolt-ons and tune? No way. Something fishy is going on here.
Old Oct 10, 2014 | 11:42 PM
hurleyguys's Avatar
on your graph it looks like they cut the baseline run short. that is why your base numbers are so low. did your friend dyno his car at the same place?
Old Oct 10, 2014 | 11:47 PM
bat6wc's Avatar
good catch
Old Oct 11, 2014 | 03:58 AM
vqsmile's Avatar
Umm . . .they're also showing torque and power versus road speed, not rpm.
Where are the shifts then? Smoothing must have been something ridiculous.
Old Oct 11, 2014 | 09:40 AM
Jeremy1607's Avatar
Haha that's because I have a JDM Skyline, so it hit the speed limiter (180km/h) at around 5,500rpm. He has removed it and at the end, he managed to get 242.5HP.
Yes, he did the tune at the same workshop with the same tuner too.
Old Oct 11, 2014 | 09:41 AM
Jeremy1607's Avatar
Yeah I asked him, he said sorry he used the wrong axis label .
He said he did the runs on 4th gear.
Old Oct 11, 2014 | 04:16 PM
07-G35-MT/S's Avatar
If the short ram loses like 5 and a good cai can gain around 10, plus that hot air sucking intake made it difficult to add timing without detonation.... 20 hp difference. (give or take 5)
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
Usman Ali
Oct 4, 2015 08:23 PM
