can i put 245/45 18 on the front end of my 2007 g35 sport sedan?
Old Oct 15, 2014 | 08:40 AM
kyodynsty77's Avatar
there is a guy selling his m45x stock rims. size 245/45 18, i know that the rear of the car uses that exact size but the front stock runs 225/50 18. can i put 245/45 18 all around?
Old Oct 15, 2014 | 09:56 AM
gary c's Avatar
Yes you can run 245/45s on your front end! Never liked the idea of having those small 225s on my front end! The 245s will give you a more controled/stable ride...Gary
Old Oct 15, 2014 | 09:58 AM
thank you... i am pretty excited about it.
Old Oct 15, 2014 | 11:48 AM
vqsmile's Avatar
Is he selling you his rims or his tires?
Rims don't come in a 245/45-18, but tires do. In general, rims would be referred to primarily by their diameter, width, offset, and lug pattern spacing. Something like this: 18 x 8, +45, 5x114.3
Remember, for proper wear and handling, a 245 width tire should typically be mounted on a rim that is at least 8" wide, regardless of whether it is located on the front or rear of the car.
Old Oct 20, 2014 | 02:17 PM
stockae92's Avatar
Man, I would be interested in running a square setup of 245 on 18" rims, so that I can rotate tires.
Maybe the car will be less understeer-ish on the track
(weird enough, I read that the Dodge Challenger SRT-8 only runs 245 weight all around on 20" rims, for so much hp and weight)
Old Oct 20, 2014 | 08:26 PM
yah... both of you are right. i was listing the tire size on the rims he had. all the rims were the same size as well as the tires. was just worrying about some rubbing, but thr guy sold the rims before i could get to them. i was thinking the same thing about being able to rotate the tires, and a aggressive balanced stance doesnt sound bad at all.
Old Oct 22, 2014 | 08:36 AM
blnewt's Avatar
Might look at this set
http://www.myg37.com/forums/private-...-metallic.html
Old Oct 22, 2014 | 02:30 PM
dofu's Avatar
20 Year Member
You can even run 255/45/18s up front
vmcarbuyer
Oct 12, 2019 12:42 PM
teamghost
Jul 28, 2015 04:52 PM
crazy_g35s
Jul 20, 2015 02:30 PM
