Eibach lowering springs grinding noise over speed bump
Hello I installed eibach lowering spring and everytime I go over a bump it's a loud grinding noise any solution to this?
[QUOTE=JKL1031;6952951]That would be a clunk, but possibly could be a strut.[/
well thts the think its like a grinding noise .... every speed bump or dip .... thats other than that is fine......
As mentioned above, did you re-install the spring wrap that was on the originals? Also, noise could be due to shot end links.
I can't find gasket for the struts ether ? Any idea where I can find them
http://discountinfinitiparts.com/par...iagram=3846215
They're a rip off but it's part # 19 in this pic
I bought vossen wheels idk what tires to go with :/. 245/35/20? I wanted to put white tire letters on them have you seen them before ? Plus I need to get rear control arms. Plus end links for the front .
got damn..
No too thick cause it can jack ur ride height. id say like a bike inner tube or something. I forgot what i made mines of, but on uneven driveways i would get an awful crunch without one.
Yea that's the same thing I get its really annoying it's been like that since 6 months idk If I should buy new struts too I have the oem ones on right now
http://www.myg37.com/forums/brakes-s...ay-or-nay.html
