Jacking up Rear
Old Dec 31, 2014 | 12:28 AM
takeapieandrun's Avatar
Jacking up Rear
Hey guys, I have a 14" lift floor jack and based on the service manual I use the rear differential. However, this doesn't give me enough lift to slide jack stands underneath either side.
Lifting from the rear driver/passenger side jack point gives enough height however. With all the torsion, Is it ok to just lift one side of the rear at a time? Like passenger side then driver side. Sorry if it's a dumb question, just being cautious haha.
Old Dec 31, 2014 | 12:41 AM
ScraggleRock's Avatar
Are you lifting one side or the whole rear? Don't lift the whole rear without lifting the front; you'll eff up your steering. If you're lifting one side, just use the half the jack point. I know clearance is tough using the rear jackpoints, but yeah, the jack points are fine.
I usually jack the front, then the rear one side at a time at the jack points.
Old Dec 31, 2014 | 01:02 AM
I'm trying to lift the whole rear. I didn't know about the steering bit. Thanks
Old Dec 31, 2014 | 01:57 AM
Yeah, if you put all the weight on front it'll screw up your tie-rod settings. Its much more sensitive than the rear.
Old Dec 31, 2014 | 09:16 PM
blnewt's Avatar
You can lift the whole rear, you're not putting all the weight on the front, the weight will now be on the jack &/ jackstands
If that were true every time your back tires went up on a speedbump the weight would shift to the front.
With a 14" lift jack you should have enough lift to put the jack stands under each side axle tube.
Old Dec 31, 2014 | 10:46 PM
Damn..must just be my car. My steering wheel was about 45 degrees off afterward. What happened when you did it?
Old Dec 31, 2014 | 11:53 PM
Urbanengineer's Avatar
How is that a thing scraggly. I have lifted the rear many times of my car through the rear lift point for service.
Happy new year!
Old Jan 1, 2015 | 12:27 AM
Don't ask me. Maybe my tie rod bolts were loose.
Old Jan 1, 2015 | 11:58 PM
herrschaft's Avatar
Yes, but make sure the front wheels are chalked or something. Personally, I put the whole car on jack stands if I need the entire rear end off the ground.
Old Jan 2, 2015 | 01:53 AM
vqsmile's Avatar
It won't hurt the car at all to lift just one side of the rear at a time, but I fear how you may be planning on doing this.
If you're aren't lifting from the diff, then the next best place is at the pinch weld point under the rear door. However, this is also the correct place for supporting the car on jack stands, so my question is: how do you then place a jack stand at the same location as your jack?
What work are you planning on doing that you need to lift the rear for anyway? If you're not planning on going under the car, and your jack is in good repair, you should be able to just use the jack at the diff and skip the jack stands altogether, BUT ONLY if you're not getting under it! (i.e. wheels, brakes, etc.)
There are other locations besides the rear pinch welds that you can place a jack stand just as an emergency backup (while the floor jack remains the primary support for the load), but it's probably not the best idea for you unless you have to have a pretty good idea of what you're doing.
LOL at the idea of screwing up front suspension by lifting the rear. How could we ever drive our cars downhill?
Old Jan 5, 2015 | 03:09 AM
Yes, thank you VQ that's what I ended up doing. Just relied on the floor jack as I was only working with the wheels.
rezendvous420
May 31, 2020 01:26 PM
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
DRG35R
Jul 31, 2015 10:23 AM
