rear bearing noise?
Old Jan 16, 2015 | 10:38 PM
NationsMostWanted's Avatar
rear bearing noise?
Noticed when my 08 Sedan is cold, higher rpms in 1st and 2nd I notice liked a roaring feeling in the rear or left rear. Almost like a bearing or rear end. But noise goes away once it's warmed up. I jacked up the left side but didn't seem to have play in that wheel though.
I'll probably throw it up on the lift when I get to work to see.
Anyone encounter this in theirs? It's definitely from the rears though.
Old Jan 17, 2015 | 04:40 PM
Urbanengineer's Avatar
Are you at stock height and suspension settings? My coupe feathers front tires like a bish.
Old Jan 17, 2015 | 09:09 PM
Stock everything, once you let it sit and it's cold, the first 10 mins of driving if you go high rpms, it makes a vibration noise. But once your warmed up, noise goes away and seems fine. I put it up on the lift at work but since car was warmed up it didn't do it again . All wheels seem tight and differential fluid is full.
rezendvous420
May 31, 2020 01:26 PM
ScraggleRock
Aug 11, 2015 10:16 PM
MyfistYourFace
Aug 8, 2015 11:58 AM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
