Headlight mod, but Light output issues.
Old May 4, 2015 | 01:15 PM
harshybar's Avatar
I recently had my Headlights painted, the guy said he put in the upgraded lense. Yes the cut-off on my driver size is cleaner but if you look at the image the passenger side is a not as crisp. Listed below are my issues, any help would be great.
- Dark spots on the floor, I tried to align the lights and the spots didn't go away.
- The passenger side is not as crisp and to be honest as bright.
- Field of light is much narrower than OEM i believe. Odd thing is everything is still OEM, so what could have changed?
I have an idea but don't know since I am not an expert. I believe the new lens are not sitting 100% correctly, so the distance from bulb is off. Could any of you please take some pictures of your light output so I can see if I am imagining things? Greatly appreciated.
Attached Thumbnails Headlight mod, but Light output issues.-img_20150420_212859.jpg   Headlight mod, but Light output issues.-20150503_233023.jpg   Headlight mod, but Light output issues.-20150501_213832.jpg
Old May 5, 2015 | 07:44 AM
harshybar's Avatar
Bump!! Nobody?
Old May 5, 2015 | 09:01 AM
Hogbone's Avatar
^driver side
Passager side
Old May 5, 2015 | 09:15 AM
Hogbone's Avatar
I done my clear lense swap and cut off mod myself. I used the clear lens from the retorfiting source.
But I'm gonna out on a limb and said something in yours is not lined up.
Old May 5, 2015 | 10:05 AM
harshybar's Avatar
Originally Posted by Hogbone
^driver side
Passager side
HOw far are you from the wall in those pictures?
Old May 5, 2015 | 10:40 AM
Hogbone's Avatar
Headlights where bench tested at 10yrds inside
Also bench tested them outside at about 60ish yrds outside
Old May 5, 2015 | 10:53 AM
harshybar's Avatar
Thank you very much for your help. Do you have any pics of them on your car? From the drivers perspective? See if the light output is the same or better than mine?
Thank you so much.
Old May 5, 2015 | 12:14 PM
Hogbone's Avatar
No I don't, I never got that far. Car is apart due to me tryin to install headers
Old May 7, 2015 | 02:07 AM
Urbanengineer's Avatar
Originally Posted by harshybar
I recently had my Headlights painted, the guy said he put in the upgraded lense. Yes the cut-off on my driver size is cleaner but if you look at the image the passenger side is a not as crisp. Listed below are my issues, any help would be great. - Dark spots on the floor, I tried to align the lights and the spots didn't go away. - The passenger side is not as crisp and to be honest as bright. - Field of light is much narrower than OEM i believe. Odd thing is everything is still OEM, so what could have changed? I have an idea but don't know since I am not an expert. I believe the new lens are not sitting 100% correctly, so the distance from bulb is off. Could any of you please take some pictures of your light output so I can see if I am imagining things? Greatly appreciated.
Did he install new bulbs? If not, the bulb is simply not pushed in all the way from re-installing after upgrading. This is a common problem. I'm making a video when I get back to my G this fall (about the service you've had done).
^driver side Passager side
Nice retrofit!
Jusseth
Sep 13, 2020 12:25 PM
bTanz
Oct 15, 2015 02:31 PM
wonderizm
Sep 24, 2015 03:09 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
attarday
Jul 15, 2015 04:03 PM
