90k service 2008
Old Nov 12, 2015 | 12:42 AM
bjo16's Avatar
90k service 2008
So I just had my 90k service on 08g35xs by my mechanic and he didn't really do too much as like I've seen others on here. It was only a few hundred bucks. He gave me the all data sheet of what they say to do and it's very minimal compared to the Infiniti manual which says I believe replace a lot of stuff. All data basically says just inspect everything , change oil, and cabin air filter. I think that was basically it. He wasn't going to change my tranny oil as it only said to inspect but I said it probably needs it so he did do that. So just wondering all the stuff infinit says do you have to follow all that and replace everything and spend a ton? I know he didn't change my coolant or anything else just looked at it. I'm going to do the cabin air filter myself.
Old Nov 12, 2015 | 09:36 PM
youngdip631's Avatar
Cabin filter removal and replace/install is easy (check youtube), buy a k&n one and youll be good for life, same goes for the 2 air filters. Right before i hit 100k miles (around 98.5k, 4 months ago) i had my mechanic flush and fill all fluids (tranny, differential, transfer case, coolant, power steering) and also the spark plugs just to start fresh as i knew i was going to be at 100k in no time and that none of these have probably been changed before (got my car at 78k so im not sure).
I purchased everything except the coolant and power steering fluids through websites/ebay and brought it all to them. The only reason i did that is because i wanted to use specific lubes that i know they dont use and i got the stuff cheaper than going through them.
With all that done and an oil change(brought my own oil there) and inspection it ran me $762 with tax.
Old Nov 13, 2015 | 12:20 AM
bluedevils95's Avatar
your car is well maintain. I just hit 75k not to long ago. each upgrade i did i flush what ever i did. The only thing i need to do is diff
Phenomenon9
Feb 14, 2016 01:11 AM
BradMD_96
61
Jan 18, 2016 05:56 PM
Kicknshift
Dec 24, 2015 10:22 AM
JASONBOO873
Drivetrain
Oct 30, 2015 08:51 AM
carnutaz
Oct 29, 2015 11:43 PM
