Is the rear diff still the best place to jack up the back end?
Old Feb 19, 2016 | 11:50 PM
08STLX's Avatar
For some reason I have never been a fan of jacking the rear of the car from the differential but I have never had any adverse effects either.
Just curious if a better spot prevails. I would guess if you jack the car up and quickly place jack stands it's not as bad.
Old Feb 20, 2016 | 08:57 AM
blnewt's Avatar
Nope, that's the best place. Why aren't you a fan of doing that??
Old Feb 20, 2016 | 09:07 AM
davewes's Avatar
Yea. It's a good spot to use. Had to jack my from the diff the other day to raise it high enough for the loft arms to clear the underbody.
Old Feb 20, 2016 | 01:15 PM
vqsmile's Avatar
It's what the factory recommends:
http://www.nicoclub.com/FSM/G35/Seda...5_Sedan/gi.pdf
(see page GI-31)
Old Feb 20, 2016 | 02:06 PM
gary c's Avatar
I would rather use the lift points in front of the rear wheels rather than the differential...Gary
Old Feb 21, 2016 | 11:05 AM
yosip1115's Avatar
My lift points are so beat up now... It's sad
Old Feb 21, 2016 | 12:08 PM
vqsmile's Avatar
Yep, that's why it's better to do the lifting from the diff and then put the stands under the those - carefully!
Old Feb 22, 2016 | 08:06 AM
08STLX's Avatar
Thanks for the info guys! My BMW had rubber pads for the jack points and it was awesome given that I had a pair of "flat top" jack stands. I also got lucky and have a squishy (technical term) pad on my jack so it helps the metal on metal contact quiet a bit. My Lexus had the same setup like the G with the "slotted" jack point which is perfect for the trunk jack but not so much the hydraulic ones. I try and get my stands on someone frame/unibody related if I can. If not I just leave the jack up and carefully work around things :0
Old Feb 23, 2016 | 12:15 PM
Mustang5L5's Avatar
I've never been a fan of jacking up by the differential. That part was never meant to support that sort of weight like that. I'm sure it's "fine" but I'd rather not use it.
Old Feb 23, 2016 | 12:24 PM
vqsmile's Avatar
It's fine if you're not a fan and would rather not use it as intended, but make no mistake, it most definitely was designed and engineered specifically to be "meant to support that sort of weight like that". You have the factory's word on it. They endorsed it so much they even put it in writing.
Old Feb 23, 2016 | 12:29 PM
Urbanengineer's Avatar
Use the "Hockey puck" method by cutting a slot into a hockey puck and lifting with a standard flat top jack.
Old Feb 23, 2016 | 09:30 PM
Cbst09's Avatar
Old Feb 23, 2016 | 10:05 PM
DeafBringer's Avatar
+1, if it's good enough for the factory, it's good enough for me.
Old Feb 24, 2016 | 09:18 AM
Mustang5L5's Avatar
That's fine, but given the issues sometimes experienced by others with rear diff bushings failing, i'll stick to using other jack points rather than the pumpkin.
(I do not have any data to show jacking from the pumpkin correlates to failed bushings and I'm not claiming it's the cause)
danoman32
Cooling
25
Apr 23, 2016 10:40 AM
nrg1
Mar 20, 2016 01:51 AM
Kingppoppy
Feb 19, 2016 11:28 PM
Bean_VQ35DE
Feb 19, 2016 08:44 PM
PTG
Feb 19, 2016 08:46 AM
