Wheel Bearing - OEM or Aftermarket?
Old Apr 2, 2016 | 06:38 PM
Sweet Lew's Avatar
Hey All,
I've got a wheel bearing that's toast. Are people going OEM or aftermarket? If aftermarket what manufacturer and on what site can I find it?
Thanks,
Lew
Old Apr 2, 2016 | 10:01 PM
vqsmile's Avatar
Lew, as I recall, there was a discussion about this in the latter part of this DIY thread:
https://g35driver.com/forums/g35-sed...ml#post6984560
Prices and such that were mentioned may be a little dated now, but it's a start.
Old Apr 2, 2016 | 11:32 PM
Sweet Lew's Avatar
Thanks!
Looks like Timken is the way to go. Much appreciated.
Cheers,
Lew
Old Apr 3, 2016 | 12:47 PM
willdogs's Avatar
Just installed timken on both front, amazing product and super silent
Old Apr 5, 2016 | 10:46 AM
07-G35-MT/S's Avatar
Just went with the cheapest thing on Rockauto.com. I'm happy.
Old Apr 5, 2016 | 01:59 PM
Sweet Lew's Avatar
Just for giggles, I called the dealer to get a quote. $600-$800!! Soooo, I just ordered a Timken off Amazon. Should be here Thursday.
Old Apr 8, 2016 | 11:19 PM
esotericrider's Avatar
Replaced my fronts
I replaced my fronts about 15k ago with cheaper Beck/Arnley which I think are just distributors. They test and buy bulk from manufacturers and rebrand them as theirs. Wanted to get Timkens cause they are apparently the best but my G is hit 200k so really was not trying to spend too much. Overall satisfied with my purchase, only thing was my bearings were fine... the noise was coming from cheap tires
Old Apr 11, 2016 | 08:16 AM
Sweet Lew's Avatar
Hey All,
Can someone confirm torque specs for the axle nut?
Thanks,
Lew
Old Apr 11, 2016 | 09:12 AM
Urbanengineer's Avatar
Look in the FSM, I think it's in the ballpark of 120 ft-lb!
http://psedog.com/cars/fsm/g35/
Old Apr 11, 2016 | 10:27 AM
Sweet Lew's Avatar
Actually, under fax-16, it's 125 nm\92 ft-lb. Am I reading that right?
Old Apr 11, 2016 | 11:58 AM
vqsmile's Avatar
You got it right Lew!
Old Apr 11, 2016 | 12:34 PM
Sweet Lew's Avatar
Ugh. Gotta back out that bolt. Over torqued it a bit.
Old Apr 11, 2016 | 12:39 PM
vqsmile's Avatar
I don't get it.
If you had seen FAX-16, why did you torque it further?
Old Apr 11, 2016 | 01:02 PM
Sweet Lew's Avatar
I don't get it.
I just got the fax doc today. I installed the hub assembly yesterday using the torque specs in the diy.
Old Apr 11, 2016 | 02:07 PM
vqsmile's Avatar
Ahh, I see. I'm going to go ahead and to post an updated comment about the correct torque spec in that thread. I just glanced back at it and the torque info given is pretty bad.
Lew, in the future, you'd do well to bookmark the (online) FSM for your car:
http://www.nicoclub.com/FSM/G35/Sedan/2008/
(hint: the index for the secions in at the very end of the list, in the "fwd" section)
EDIT: Lew, did you also use the incorrect spec for the front brake caliper torque member (i.e. the caliper mounting frame). It was given as 90-115, and the manual lists it at 98.
