Air condition delay
Old Sep 23, 2016 | 08:13 PM
douglas555's Avatar
Air condition delay
So recently when I turn on my air conditioning it delays several minutes before kicking in. It never did that before. There are other times it comes right on.
2007 G35X with 165,000 miles.
Any thoughts?
Thanks.
Old Sep 23, 2016 | 09:37 PM
Urbanengineer's Avatar
Clutch.
Old Sep 26, 2016 | 02:38 PM
douglas555's Avatar
Is that a major repair?
Old Sep 27, 2016 | 12:12 PM
BradMD_96's Avatar
If it is the clutch, it might be easier to replace the whole compressor.
I bought a used comp for $50 and replaced it in about an hour. Then get the system vac'd and refilled.
Old Sep 27, 2016 | 12:14 PM
vqsmile's Avatar
If you are handy, it is doable (yourself):
https://g35driver.com/forums/g35-sed...ise-video.html
https://g35driver.com/forums/g35-sed...placement.html
Old Dec 11, 2016 | 11:51 PM
douglas555's Avatar
Fixed!!!
Thought I'd post here as well in case anyone is still having this problem.
I replaced the blower relay and the AC and heater are working perfectly!!! Genius fix whoever figured this one out. I saved a HUGE amount of money by fixing this one myself.
Easy to replace:
1. Remove cover to fuse box right beside drivers left foot
2. Remove panel around where that cover was (remove bolt-like attachment on front of panel and the rest just pulls off)
3. Remove 2 bolts holding fuse box
4. On back side of fusebox replace bottom relay (looks like little blue box - I bought one on RockAuto - about $30 - searched for blower relay)
5. Put everything back together
Hope that is helpful to anyone.
RATED G
Engine - Complete Motors CDN
Dec 8, 2018 11:16 AM
Gandostar
Sep 26, 2016 07:57 PM
RATED G
2nd Gen (V36) Sedan
Sep 24, 2016 02:58 AM
Kiva.hi
Sep 23, 2016 03:50 AM
Swaglife81
Intake & Exhaust
Sep 18, 2016 10:38 PM
